Record with ugc102guitar link then play track on pc speakers
  • Thread starter Thread starter maggot_brain
M
maggot_brain
Hello
I have a behringer guitar link ucg102, and as a speaker I use my guitar amp. What I would do is, once I recorded a track, I would like to listen it on my pc speakers instead. Is there a program that allows to do it, without having to switch devices in the options? I hope I've been clear enough :D, thanks in advance
What software are you using to record? It looks like this is functional enough...it may work better if you plugged your PC speakers into the headphone output of the unit. But, there may be another option depending on what software you're using.
Miditech English > Samplitude > Audio Production > MAGIX Pro
Try that ^ It should allow you to have a different output device from the input tho' NOT with ASIO drivers so latency might be unacceptable. ...Has to be said, these dangly USB devices SEEM a cheap option but, as you have found, can be very limiting. I guess cash is an issue but a good starter Audio Interface is the M-Audio M-Track, the Mk1 if you can find one.
I use Reaper, finally I plugged my pc speakers in the output of the ugc102 via the line in of my speakers with an adaptater I remembered I had... Thanks anyway for your help guys, ecc83 I took note of this device if I want to change someday ;)
