Shadow_7
I've out grown my Avenson STO-2's (or would like to anyway).
I've tried Shure SM-81's and they're not quite the sound I'm after. And it's proving far easier to wind proof the Avensons on the cheap than the Shures.
What I'm looking for is under $1,000 (USD). Flat frequency response (What you hear is what you get). Cardioid pattern since I'll be joining it with a camcorder at a distance. High SPL since I'll be recording large brass bands with drumlines (indoors and outdoors). Low self noise since I'll also be recording SMALL brass bands from the same distance. And at a minimum wind proof, preferably heat, humidity, and maybe even rain proof. And they must sound good on brass instruments and drums outdoors.
Pros and Cons of what I have.
Avenson STO-2's
-Pro: They sound true to the source.
-Pro: They are relatively immune to wind with lavalier wind foam and rycote wind jammer. But not completely immune.
-Pro: They handle high SPLs well.
-Con: They lack a little low end presence (Tuba gets a bit muffled)
-Con: They have high self noise
-Con: They're OMNI patterned so not much of a stereo image without proximity and greater than 90 degree orientation.
Shure SM-81's
-Pro: low self noise and high gain
-Pro: They sound good and have a good stereo image.
-Pro: They come with a windscreen.
-Pro: They're built like tanks.
-Con: There seems to be some mild distortions at the higher SPLs. Or maybe it's just some brightness / harshness that I'm just not used to.
-Con: They're not well matched as a pair. Although okay with distance.
-Con: The stock windscreen is useless in winds > 10mph +/- 7 mph.
-Con: even with the stock windscreen and homemade fake fur socks over the mics they just can't take significant winds. Winds which are fairly mild relative to these parts have the capsule clicking / bottoming out, where the Avensons just get a low end rumble effect.
At the moment I've thought about AT 4041's, Beyer MC930's, Crown Sass-P MK II, even NT5's. But I"m looking at solving current issues and not creating new ones. Current issues being self noise, polar pattern, weather immunity, better low end.
The Shures address some of those issues, but are still not quite what I'm after. The recordings I've made so far (indoors) are good, but don't quite sit well with me. They bug me for some reason. Sure the self noise is better, the stereo image is better, the low end is better, but I'm just not liking it for some reason. Too bright? To brittle? I can't quite put my finger on it yet. I'm looking for something a little more mello, but detailed. I'm basically wanting my Avensons with lower self noise and a cardioid pattern. And a better windscreen.
In all likelyhood I'll need to sell my current two pairs to pay for the next step, so they HAVE TO BE better. Ideally a pair of ribbons would work for my needs, but those are probably the worst option for travel and outdoors, so don't bother recommending any of those. Unless there's some bulletproof windscreen on the cheap that I don't know about. So $1,000 for BOTH mics (Total) and hopefully wind proofing included. I really don't want to buy $700 rycotes zeppelins x2, I'd rather DIY. But if I can get something acceptable for $100-ish(for both) like I did with the Avensons, that's good enough.
Thoughts?
Avenson STO-2's
Shure SM-81's
Thoughts?
