T
The Audio Cave
Rather than post this in response to a generic question about levels (like I did in the mixing forum and then deleted) I'll do it here... there is a HUGE misconception about tracking levels when recording in 24-bit daws.
Instead of going into detail of why not I'll just say trust me on this. If you're running a mic into a preamp and tracking to daw peaking at -3 or -4, and you're using most any "budget" preamp you might be doing the wrong thing. Lowering the tracking levels can possibly make an audible difference.
Edit/Clarification: Actually, keeping any signal (keyboard, DI bass, whatever) down a little more is a good idea for reasons which will be clear later and have nothing to do with the "budget" preamp reason. The cheap preamp reason is a tracking reason while the others are mixing related. The preamp thing even includes more expensive pres but for a mixing reason. The focus was initially on budget pres because that's what we start off with.
I'll explain later if you want (or maybe someone else will) but record using -10 on the digital scale as a peak reference. Try to make most of your incoming signals peak around -10. There's a really good reason for this which will be partly evident when you try it a few times.
In the interest of keeping this post short... trust me.
It works much better in person when you can see it AND hear it.
. You're off to a good start from what I've seen, but it's waaaay to early to expect anything resembling "trust" from the Great Unwashed. Welcome and good luck
