T
trion12
Hi,
I have a Roland GR-33 guitar synth that works fine for live use through my AER Compact 60 amp.
When I take the line out from the GR-33 to the LINE In of the Mbox to record with however the signal is extremely crackly and buzzy. This noise is only present when I play a note. It is not there otherwise.
I have tried LINE and Instrument input settings on the Mbox to no avail. The input levels are not overloaded as I am nowhere near the red.
When I plug the GR into my amp and then take line out from the amp to the Mbox the problem is gone.
I also tried DI out from the amp to the input of the Mbox but there appeared to be no signal getting through.
When I plug my electric guitar directly into the Mbox there is no problem.
I am at my wits end with this.
I want to use the GR to record but can't.
Any thoughts?
Any thoughts?
