Zona Mona
Can anyone explain what point to point wiring is and why I would want it?
Zona Mona said:Can anyone explain what point to point wiring is and why I would want it?
Farview said:Point to point is a term normally used as the opposite of printed circuit boards. There is a sonic difference between the two. That is the main difference between the early JCM-800's (the 'good' ones) and the ones from the late 80's. The circuit didn't change but they went from p2p to circuit board and it changed the sound of the amps.
You are correct, but the earlier ones were not pcb's like the later ones with everything mounted to the same board. Stuff was mounted to the board but there were still wires all over the place. The point when it changed was when the inputs became horizontal. It was a couple years after that they added the silicone diode circuit.spoonie g said:This is incorrect. Marshall stopped doing point to point wiring in 1972. The only advantage of having point to point witing is easier maintenance and resale snobbery.
Farview said:You are correct, but the earlier ones were not pcb's like the later ones with everything mounted to the same board. Stuff was mounted to the board but there were still wires all over the place. The point when it changed was when the inputs became horizontal. It was a couple years after that they added the silicone diode circuit.
The diode distortions ones were only the later channel switching heads. Marshall has a habit of changing the circuit before changing the name. The ones with the diodes are , for all intents and purposes, JCM 900s.
P2P wiring makes a difference in comparison with what will eventually happen. pcb's warp and crack under heat and stress.
SteveK said:My main gigging and recording amps are made by Andy Fuchs,
Light said:That dude has GOT to change the font he uses for his logo. Great amp, but how many times have you been asked why you are playing a "Fucks" amp?
Light
Actually the only two who have ever asked were my bass player and drummer.I don't know if a different font would really make a difference though...
