T
TamirE
I have an Ibanez S470.
I also have the pickups - seymour duncan JB-4 (humbucker), cool rails (dual rail single, actually a humbucker), fender lace sensor gold and fender lace sensor blue.
What I have in mind is using the JB-4 for the bridge, cool rails in the middle and the two lace sensors as two singles somehow fitted into the neck humbucker cavity.
i want to install 2 "DPDT on-on-on" mini-switches, one for the cool rails to make the choice of series/split/parallel possible, and one for the two lace sensors, hopefully doing the same. i'm not sure how it will work with the lace sensors because when using usual pickups you must have one of them reverse wound and with reverse polarity... can anybody here help me with this?
also, should i do a humbucker split in the bridge+middle position too? right now there is a split (the current configuration is JB4-FLSGold-FLSBlue, the FLSblue is a single in a humbucker cavity, which looks bad and sometimes picks up feedbacks from the bass amp....).
Please help. my guitar should be back from fret grind&polish + setup in a few days... i want to decide and write down the schematics untill then hopefully...
thanks in advance,
TamirE.
thanks in advance,
TamirE.
