C
cerulean
Hi everyone.. Just recently purchased a VF16 and now I am looking at buying some mics to do some piano recording with (both solo & with other instruments/singers) -- The musical style will be mostly jazz/contemporary christian however I do plan on recording an occasional classical song.
The pianos I will be recording on consist of a 6' Steinway (c. 1910), 6' Petrof (1996) but will probably also eventually record on other pianos as well (gigs/tours/etc..)
The Steinway is a living room piano (I'm thinking this will cause me to setup close mics under the lid w/blanket) and the Petrof is in a church (the church is large ~1100 seats)
I would like to keep the price for the pair (I'm assuming it would need to be a pair) under $300 .. From what I understand, many of you like using/recommend the MXL603's, SP B1 or B3, MK012's..
A quick question about the MXL603 .. I heard that they perform best from a distance (which I assume means in the room so it will pick up a lot more of the room?) and will distort when being close. Is this true or was the post I read a problem with that particular mic/setup?
Thanks for any advice regarding the mic selection..
