C
contactdannyd
UPDATE: Day five, trying to sync the 2488 to Logic 8. MADE SOME PROGRESS, as the two are finally synced; however the time quality of the sync is still to be determined. Here is the one and only way the two can time communicate: Logic is the MASTER using MTC. The midi/usb interface cable needs to be hooked up as follows: USB into computer, the out of the cable to the IN of the 2488. The IN of the cable to the out of the 2488. In Logic, select INTERNAL on General sync page, 25 fps, and ALways. On the MIDI sync page in Logic, select checkbox for Transmit MTC. Select the usb/midi cable interface which should show up. On the 2488neo, in the sync menu: source External, frame 25, generator off of MTC. Make sure logic and the 2488 are running at the same tempo. And place two or three measures in front of your song. Hit the play button on Logic, then play button on the 2488 and the two will run. The 2488 will beginning running in sync. Next I will determine the accuracy of the sync. Important: For a Yamaha XS synth, the sync has to be on Auto, not MTC or midi or it will not play. Essentially, MTC is used only for controlling the 2488.
