Stratomaster
Active member
This is probably better asked in the mixing/mastering forum but...oh well- My problem is LOW VOLUME MIXES!--we're talking at about -18 to -20db rms average when analyzed in wavelab! By the time I limit these suckers up to a max of about -13 to -12 db average the mix doesnt really resemble the original-and its STILL not up to par loudness wise with commercial cd's. So whats up with that?
A little info is necessary I suppose-when I record to cakewalk(through my tascam tmd-1000 board) I get the levels as hot as I can-without clipping(usually) and when I mix-according to the level meters on the stereo out--Im also pushing as hard as I can there without clipping. I then bounce the entire mix to an open track-I then export this track to, say the desktop where I can open it in wavelab to do my final tweaks. But what a scrawny sight the wave is-Ive imported some pro tracks and the difference visually in the wave is tremendous-by the time I limit it(twice usually with an L1)-its starting to resemble the pro stuff-but the amount of processing changes the mix.
My guess for the cause of this-would be peaks-on things like snare drums for example-I've been hesitant to use compressors in my mixes-because to my ears the mix sounds decent-and to me the less cheap plug in effects-the better. But I know this can't be normal-something is wrong.
Anyone have any ideas?
Thanks!
Thanks!
Well, I dunno if this help, but I think I do my best to help you out. Hope you don't get more confuse with this...
moskus...
yes, moskus did also... and so all those million of Cool Kids. BTW, if you haven't read it, please, I urge you to read this legendary thread by sonusman.
