My first impressions of the SP C1
  • Thread starter Thread starter Dot
D
Dot
I wrote this a couple of weeks ago, and have noticed comments on it appearing around on the net. I thought I'd copy it over here for comments and discussion. I'll also be posting further comments as I audition the mic in other applications, as well as testing the SP T3 valve mic.
– Dan Richards
My review of Studio Projects / 797 Audio C1 Condenser Mic. [ great reviews at the link, too ]
The C1 arrived today! I'm one of the first people in the US to get one of these babies.
First impressions...
The box was well-packed and much bigger than I expected. Even though I waited a month for it to get here from China, Warren at macmidimusic.com was nice and professional. I'd recommend them for any purchases.
$209 was the price of the mic. With shipping, the total was $223.
Opening the Fed Ex package. Firstly, what you see and get are way more than expected for a $200 mic. The first thing I see is a well-printed catalog of Studio Projects mics – w/ 797 Audio company history as well as the other mics in the product line. And of course, there's a warranty card.
Next, there is this beautiful little [ and very solid ] flight case. Warning, women may want to use it for a purse. This thing is cool, and alone would probably run $70 or so. BUT, the literature and the picture say the case should have locking latches. I did not get the case in the pic and it does not have the spiffy combination lock. I'll call Warren about this. Still, the case I have is very nice.
Next, I open the case. There's the mic – it's a big fucker. Also a very nice EA-1-type shockmount [ Neumann's shockmount is $150 by itself ]. There's also a nice big windscreen cover.
All this adds up to WAY more than you'd expect for this kind if money – even if the mic wasn't as good.
Now, on to the mic. This thing is pretty brushed silver metal, over 8" long and as thick as your wrist. Very well-constructed – this is not cheap stuff, none of it.
I set it up easily on a stand and plugged it into an HHB Radius 40 – which I left on the same settings I'd been using for a recent project.
The C1 has a cardiod-only pattern and there are no db pads available on this model. It's bigger brother, the C3 , allows for multi-patterns.
So, let's turn it on. As I stand in front of the mic and just speak, I immediately realize I am in U87 territory. The proximity results of the C1 and U87 are virtually identical. There's a sweet spot on the mic from about 4" - 10" away that acts just like a U87. I auditioned the mic w/ a pop filter from these guys.
The mic is hot, more so like a TLM103. I instantly got about 4db more signal than w/ my AKG414. Another thing I'm noticing is that I hear the mic picking up much more noise from outside and in the room than my 414. The reason I like the 414 is because it only picks up sounds in a close proximity – which helps since I have a studio in a apartment. But I also love the 414. Anyway, back to the C1.
I cut a track of lead vocals w/ flat EQ all the way through the chain. The mic responded beautifully. It has this "sheen" that is characteristic of Neumann. There is a nice presence on the vocals. Every little nuance is heard. There is no "edge" or cheap sound. This is smooth. This is an expensive sound.
Next, I tried a vocal track w/ +3db boost at 1.5K and 5K on the Radius. Boy, you could hear it in the mic. A bit too much.
Next, I tried an EQ setting I almost always use on every vocal track I've ever recorded w/ a U87 [ which is over 20 of them ]. About 2 db boost at 1K and 8K [ though my usual boost is 10K, but that is not available on the Radius ]. Not quite right w/ this EQ. So, I switched from 8K to 12K. Here it is! This is a U87! No lie.
Now, keep in mind that even different U87's sound different, but if I close my eyes and just sing through this mic, I would have said U87.
I next tracked some trombone. Really nice smooth sound, no blast. The mic is hot and of course if I had a pad I'd use it, so I tried different positions and was able to get a nice smooth sound. The 414 has sounded terrible on trombone, and I've been recording it w/ an EV N/D257 – which has been sounding great. For horn pops and section work, I'd still probably choose the EV, but for creamier melodic stuff, I'd go w/ the C1.
I next tried acoustic guitar. This was pretty nice, but even a U87 has never been a mic I've liked to use on guitar. Actually, the C1 sounded better than a U87 on the acoustic. It seemed to be more forgiving of mic placement and proximity.
Conclusion: This is one of the most exciting purchases I have ever made. I am truly in the presence of a great, classic-sounding mic. Now, keep in mind that even a U87 does not sound great on everything – nor on all voices – but as far as I'm concerned, I have a U87 in the house now. Being that a U87 has been THE standard mic in studios for years and has been responsible for more vocal tracks on records than any other mic, a mic that works and sounds virtually identical is a good, shrewd investment for any studio owner. Actually, the C1 is quieter than a U87 – and due to its transformerless circuit, line noise and interference from computers and other devices is not a concern.
The C1 is sensitive – and like I said it picks up more of the room – so, that if you have a shitty, boxy-sounding room, you'll hear it w/ the C1. On the plus side, using this mic can help you to make your room sound better by giving you excellent feedback on the sound of the room and the materials.
I have staggered Sonex in my studio and also a live end w/ a mirror and a dead end w/ a big curtain. I cut the tracks w/ the C1 facing the curtains. I'm very happy w/ my room sound.
Bottom line: If you are looking to make your first large condenser purchase, this mic is light years ahead of anything else for under $1000. I would highly recommend it over the TLM103, which'll run you over $700.
If you are working w/ a female singer, get a C1. Period.
If you have a large condenser and are looking to buy another one. Look no further.
If you are looking for a nice pair a large condensers for stereo recording, get two of these beauties.
For $200, this is the choice for an inexpensive condenser. As a matter of fact, this could be the choice in any price range. This mic – while not perfect for everything – is as good a large condenser mic as I have ever heard. [ I've worked w/ just about every industry-standard mic. ]
Yes, you can get a $200 mic that acts, sounds and feels like a $2000 mic. Not only that, but you also get a spiderweb-type shockmount, windscreen and a bitchin' case to boot.
For some reason that review doesn't sound very objective or unbiased.
Why, BBB? There's lots of gear I don't like, but in this case the mic is amazing. What more can I say.
Many people have order a C1 based on my review, and they've all been blown away.
I know Dot on another site, and I think he's totally legit. It's only one man's opinion, but you could say that about any review.
I personally wouldn't buy ANY mic that hasn't been around for a long while, and hasn't built up a strong reputation......but that's just me. I'm a wacky guy.
Welcome Dot
Hi WA, and thanks for vouching for me. I figured I'd run into a few familiar faces here. : )
Dot- I'm the Artist formerly known as Spellbound on another site. I must have been smoking a fat one that day.
Ah, yes, Mr. Spellbound. Nice to see you here, my good sir.
JerryD,
No my friend, it is not me, but I am here to participate if and when I am needed, or until such time I put my foot in my mouth again. LOL As a newbie, I have a tendency to do that, but I am just simply misunderstood.
In either case, I hope this thread can be void of political issues. BTW, Harvey and I are fine, we talked today. I asked him to give me lessons so everyone will understand what I mean. We laughed, and things are fine.
I say, blame it all on C7sus!
microphone model #
Dot, I can't seem to find C-1 on the 787 site? is it not listed there yet?
martin
And...
And this is STILL NOT SPAM in my opinion. If ANYTHING, THIS is harrasment by C7sus. No more please, C7sus.
My dear, RE, I know Spam when I see it.....
Spam and cheese, spam and eggs with Tobasco sauce.....spam omelets.....
C7, you remind me of a broke ass Alec Baldwin....how about if Dragon doesnt kick Alan off the board, you will leave the country.....get a life man and lets just have some fun......
Amen.
C7- no offense man, I hope you can just let this go. Its you against the world at this point, and you have no reason to be so upset to begin with. Let it go, maybe you'll get lucky and get to tell us all "I told ya so" Til then, truce...
Good to know lots of people like the mic.
The review was just a bit too glowing for my taste. I'm just a bit skeptical when a mic review implies running, not walking, out to buy a mic and stating that the mic may be the best mic for any price range. It really sounded like a sales pitch.
I'm sure you love the mic. I can't wait to check one out in person before considering buying it.
Matt
