RickW
Don't read this
Does anyone know of a parts or manual supplier for vintage Music Man amps? There's a repair guy in my area but he's outrageously priced...like $200 an hour! I want to fix some cosmetic issues (corners, handle, etc...mainly pitted, rusty chrome). I'm also looking to replace the tubes (I believe the originals were still in there). I don't really know squat from tubes, but the ones I'm replacing are Sylvania 6CA7 EL34 (4 of them) and i'm not sure if these are still available or if there are replacements. The amp is a 1976 (?) Music man HD130 head. It actually sat (since new) on a friends houseboat until I got it maybe 4 years ago. I let it sit until about 2 months ago when I wanted to use it as a rehearsal amp. It worked fine for a couple of weeks but then it started to cut out. I had to shut it off and turn it on again, only to have it cut out again a few minutes later. It did this a few times before I turned it around to discover that 2 of the tubes were incredibly lit up...like the whole tube was a bulb...and I haven't turned it on since. I took the tubes out with the intent of replacing them to see if that fixed the problem, but I'm thinking that something had to cause just those particular tubes to react that way and not the others. So, I need to find some info on these and there doesn't seem to be much available. Any info would be greatly appreciated. Thanks.
