tkingen
Djembes Rock
The best mic preamps from MAudio seem to be the Octane, Tampa and DMP3. I wonder if anyone has any information on which preamp chips are used for them. Are the the same or different?
Thanks,
Terry
Thanks,
Terry
Alexi said:dont they use burr brown's?
Alexi said:you should check the rme quadmic out, sounds great, and is as affordable as the dmp3
tkingen said:I know that the DMP3 uses Burr Brown's, but there are different Burr Brown chips available for this purpose. For example, the DMP3 uses one that is less expensive than the Burr Brown's that are used in the Toft ATC-2 or Safe Sound P1, which I believe are INA217's.
chessrock said:If you check Digikey, you'll notice the INA-163 and the INA-217 are the exact same price.![]()
And the 163 is used in some pretty high-end stuff.
tkingen said:Very interesting! I had read somewhere (maybe another forum?) that the INA-217 was considered a step up from the INA-163. This seemed to make sense as some mid priced pres were using the 217's, and some of the lower priced (that I knew about) were using 163's. But, maybe not!
Any thoughts on the difference in sound between the two? What are some of the more expensive pres that are using INA-163's?
Regards,
Terry
