B
bdemenil
A friend of mine just got a Mac 933Hz G4. He uses protools LE (with digi 001). I have a PC with dual AMD XP1600s. We both have the Waves RVerb plug-in (a notorious CPU hog), and so we decided to compare CPU power. His Mac was only able to run 2 RVerb plugins simultaneously. My PC can run 7-8. So, even if you half the number that my PC can run to take into account the dual procs, my PC still has a significant performance advantage.
To put things into perspective, when I was running an AMD thunderbird 1.2 GHz machine, I was not able to run more than 1 RVerb at a time. So the G4 933MHz is significantly more powerful per clock cycle than the original AMD athalon series. However, it looks like the G4 is slightly inferior to the AMD XP series - on a per clock cycle basis. Consider then that the fastest G4 is 1GHz, and the fastest AMD XP is 1.67GHz(XP 2000), and you have a very significant speed gap.
So I have already established that AMD's top processors are in the neighborhood of twice the speed of Apple's. Now, let's take price into consideration. The following is the spec from Apple's online store for a basic 933MHz G4 :
Price : $2,299.00
933MHz PowerPC G4
256K L2 cache
& 2MB L3 cache
256MB SDRAM memory
60GB Ultra ATA drive
SuperDrive (this is a DVDR drive)
NVIDIA GeForce4 MX
56K internal modem
Mac OS 9
Here is a price quote from http://www.goroyalpc.com/ for a pre-built PC with an AMD XP1900 chip - I chose only good name brand components. Otherwise, I could probably shave $150 off this price.
ASUS A7M266 DDR Motherboard
AMD XP 1900 Palomino CPU (1.6GHz)
Volcano 6cu+ 7000RPM CPU Fan
Mid-Tower Case w/ 300W power supply
Kingston 256MB 266MHz DDR RAM
IBM 60GB 7200rpm HD
ATI Radeon VE 32MB DDR Video
TEAC 1.4 MB Floppy
Sony 52X IDE CD ROM
Generic 56K Modem
105 Key AT or PS/2 Keyboard
Standard Serial or PS/2 Mouse
Windows XP Home
Assembled and Tested
1 year Warranty
Your total: $977.00
Add to that a DVDR drive (because apple forces you to purchase 1 with their G4) - $ 359 for the PIONEER DVR-103 (records DVD at 2X - I think better than apple's superdrive).
Grand Total : $1336
(Note that neither the apple nor the pc above ship with a monitor)
So the the apple G4 above costs 72% more than an equivalent PC which is about twice as powerful. The Apple does not ship with OSX (that would cost more), nor is it capable of using DDR ram.
I'm not going to get into detailed O.S. comparison right now, but from my experience, Windows, especially 2K and XP, hold a strong advantage over Mac OS in stability and versatility.
Come to your own conclusions.
Note : RVerb on the G4 was running as a protools RTAS plug-in, while the RVerb running on my PC (winXP) was running on ntrack as a directX plug-in. There is probably some difference in efficiency between the 2 versions of the plug-in. However, my guess is that whatever differences there are pale in comparison to the huge discrepancies in performance. Also, all instances of RVerb were running in their default setup.
Price : $2,299.00
933MHz PowerPC G4
256K L2 cache
& 2MB L3 cache
256MB SDRAM memory
NVIDIA GeForce4 MX
56K internal modem
Mac OS 9
IBM 60GB 7200rpm HD
TEAC 1.4 MB Floppy
Sony 52X IDE CD ROM
Generic 56K Modem
Windows XP Home
1 year Warranty
Your total: $977.00
Grand Total : $1336
