M
Musart
LiveSynth PRO 1.2 and Sonar 2.0 XL
Hi All, (i posted the same thread in Cakewalk newsgroup)
I have a strange problem with LSPro and Sonar :
When i setup some SFonts (SF2) instruments routed in LSPRO , I randomly loose the sound of one or more instruments. Sometimes i need to change channel and/or patch and go back to my original channel and /or patch setting and the sound come back. I've tried polyphony setting (lower and higher than the default) and this does not solved the problem. All my track settings are ok (ie : Output, channel, patch).
I wonder if you have (or had) the same problem ... I don't know if it's a Sonar or LS problem ...
By the way i own Sonar 2.0 XL and LSpro 1.2. SBLive ! and Win XP.
Do you recommend Vsampler instead of LSPRO (i just want to play SFont samples).
Musart
Musart
