?/Light: protruding fret ends on bound board
  • Thread starter Thread starter notCardio
N
notCardio
I walk the line
There's a great deal on a Jazz bass here, but the fret ends feel like the board's dried out some, but it's on a bound maple board with a gloss finish.
Is this something that rehumidification might fix, or would it be something more serious? Kinda hard to file fret ends on a bound board, isnt it?
Once the binding and f/b has shrunk leaving a smidge of fret over the edge no amount of re humidifying will correct it. Wood just isn't as forgiving as that and the fret tang has also found a new place to sit. You'll need to get them stoned flush and polished once you have the thing humidified correctly and the whole thing stable. And yes it is a tricky job that is best done by some one with a feel for it. It requires both carefully filing them flush and also re polishing/burnishing if required. One reason why I'm not a great fan of lacquered f/b's.
Crap. I was afraid of that. :(
Thanks for the info.
What Muttley said. That said, dressing fret ends is not that expensive. Unless you are talking about a very inexpensive instrument, it probably shouldn't be enough for you not to buy it.
Light
"Cowards can never be moral."
M.K. Gandhi
The thing that flagged me a litle was the "bound maple" they can be a bit more of a pain than others. Having said that it wouldn't stop be buying it and having it done. I'd charge in the region of £30 - £40 to dress the fret ends and check set it up. Whats that $50 dollars ball park.
Closer to $60-70.
Light
M.K. Gandhi
Well, that's different!
I thought dressing the ends would be prohibitively expensive because of it being a bound board.
Now I have to see if they still have it.
Dressing bound fingerboards is not that much harder. It's only when you have to refret them that they are much different.
Light
M.K. Gandhi
