M
moelar2
Greetings,
Well, I’m happy to inform you that I just purchased an echo Layla (hopefully that’s a good thing ). I’d like to tell you guys what my setup is so that I can get some suggestions …
Here’s what I’m using:
· AMD Athlon w/ VIA chipset (don’t remember which one, but it is compatible)
· 512 RAM
· 1700 mghz
· Cubase VST32/5.1
· Mackie 32*8
Along with my layla, I purchased an eight channel TRS ¼ inch snake. Some of my questions are:
1. Where should I take my signal from in the mackie? Direct outs? Sub outs? Inserts? Please, if possible, offer that pros and cons to each.
a. Since I purchased an 8 channel TRS, I’m currently setup to take the signal from the Direct outs or Sub outs…
2. Monitoring – how should I monitor? Should I monitor the incoming signal form MixB on the console or should I monitor it as it comes back from the Layale (presuming I’m feeding it back to the console?
3. I noticed that if I set my general WINDOWS sound to be outputted from layla outs1-2, I can’t use those same 1-2 to output sound from CUBASE.
My main concern is with respect to maximizing the 32*8/Layla combination.
THANKS!
· 512 RAM
· 1700 mghz
· Cubase VST32/5.1
· Mackie 32*8
THANKS!
