H
HollowMan1975
This is driving me nuts! I have a degree in Engineering and for the life of me I cannot figure it out.
I have 2 humbuckers and two 500k rotary pots. I am trying to wire them so that each pot controls one of the humbuckers. So if you turn them both up, you get both humbuckers, and if you turn one down, you get sound from the opposite onely. The only way to get "no sound" would be to turn them both down to zero.
When I wired it up like this: http://www5.ocn.ne.jp/~dgb/index_e.htm (see diagram 2H57, about half of the way down), if either pot is turned down, you get no sound out of either pickup! This makes sense, since the pots are wired in parallel with the output jack, if the current can't short through one of the pots, it simply jumps over and shorts through the other one. I simply want 2 PU's with separate volume controls with no tone knob.
Does anyone know how to do this?
. If you want just the bridge pickup, then select only the bridge pickup, same with the neck pickup. If you want both, then select the parallel position and play with the volumes to get the sound you want. I'm not entirely sure they can even be wired to do what you described.
