Help with PRE AMP
  • Thread starter Thread starter WIZZLE
W
WIZZLE
Hey, whats up folks, I been doing some research and reading all the wonderful things yall have said for me to get. I have still been using the cheap computer mic plugged right into the mic in port on my sound card. I just got a shure sm 57 and a art pre amp, what I need to know is how to get sound of my computer. I read the booklets and everything so its hooked up right, but I cant get any sound when I record into ACID. WHAT DO I DO?
first off, make sure you are going into the LINE IN of the soundcard....secondly, go into the soundcards mixer and select that you wanna record from the LINE IN.......
Thanks man I didnt even know that was what you had to do. Now I got this problem, when i am monitering the mic levels using ACID i seem to only be gettin levels on the left side, and only when I get loud it comes out of the right side. How do I switch that, I dont see a L and R switch on my pre amp, so what do I do?
One mic only makes one signal. Stereo is two signals.*
As for why it only appears on the left input, your soundcard's line in is probably a TRS jack, with the tip receiving the left signal and the ring receiving the right signal (that's the standard arrangement of a stereo TRS jack). You're preamp has a TS jack (or you're plugging a TS plug into it), which means you're connecting the ring of the soundcard input jack to ground. Ground is supposed to be "nothing." I suspect that when you crank the output way up, you're really getting some crosstalk through the common ground, which in an ideal world wouldn't be there.
*In the interest of full discussion, and to avoid someone gleefully pointing out my "error," there are stereo mics that produce two signals. Basically, they're two mics elements in one case. But the SM57 is certainly not one of them.
Ok, well what do I do or is there anything I can do to get the stereo sound? Or will I have to record all my vocals in mono?
Well ... your tone suggest that recording your vocals "in mono" is a terrible thing. I'd suspect that something in excess of 90% of the vocals on the records you hear on the radio where recorded "in mono."
A few notes (I'm not sure if these will be helpful or not):
- The sort of prototypical way I'm used to thinking of a recording is: you record a bunch of tracks to your multitrack (all at once, one at a time, a bunch at once with a few overdubbed after, whatever). Generally, these are "mono" -- that is, the rhythmn guitar is just on one track. Then you mix the whole shebang down to stereo, and pan stuff wherever you want it, stick effects on it, etc.
- Just because you record something in mono doesn't mean it has to be all on the left channel or all on the right channel in your final mix. (I apologize if this is obvious to you.) When you mixdown a multitrack recording to stereo, it would be rare for an individual track not to be panned somewhere between hard left and hard right.
- Sometimes you might record a single "event" to two tracks at once (i.e. "in stereo"). Solo acoustic guitar, for example. Or a piano. You do this by using two microphones (or sometimes more than two, or sometimes a "stereo mic" which -- as mentioned above -- is sort of like two mics in one case). In my limited experience, a lead vocal isn't usually recorded in stereo. It can be, though. Basically, you'd be picking up a more "complete" sense of the room sound, if you do that. A brief note on how: set up two mics in a standard stereo arrangement (XY, ORTF, M-S, baffled omnis, whatever -- there are web sites that describe 'em all) backed away from the singer a bit.
you know what, that does make a log of sense. I guess I was a little nieve (hope thats how u spell it) because when I was monitering the sound it was only being shown on the left side. I recorded some vocals in mono and its just a strong and sounds good. Thanks for you help man.
