jrhoden
...And Justice For All
ok using the picture below as a visual guide i have my esp out to the ts9 tube screamer out to the boogie triple rec
the g-major and the dod graphic eq are run thru the fx loop of the triple rec.
the marshall 4x12 is mic'ed with a shure sm 57 out to the lexicon lambda and then to the input of the dell via usb
the headphone output goes into the behringer mixer and headphone out for monitoring....
its a real real simple setup for very basic recording...
now...the issue is when i change the gmajor settings and record all the different settings sound the same on playback , even with adjusting the mic.
when i sit in front of the cab and listen as i play normally they all sound different....i even tried backing off the gain...sounded like pure shit !
what am i missing here?
--- oh pooh is 38 years old
