W
William Choi
Is it possible to install an extra sound card and use it?
Im sure that the programs I have, Cool edit Pro and Native insturments pro52, allows you to specify which soundcard you wish to output to or input from.
I was thinking of trying to install another Soundblaster Live value into my computer so that I could out put Native Instrument's softsynth through one and record with the other using Cool Edit Pro.
The reason:
Because usually softsynths(not samplers) utilize a waveform which most be processed and oscillated within it's own processing unit. Anyways, the point is that it has to be outputted as a wav.
Therefore to record it, I have to set my soundcard to record a wave form.
But if Im recording from a multitracker with tracks going on in the playback, the playback will be recorded also.
So In installing another secondary soundcard and sending the output of the softsynth through that, i will be able to use my Line In input of my primary soundcard, thus, only recording the softsynth and not the entire mix.
Understand yet?
Has anyone tried this?
Im worried about how it's set up on the operating system.
Will it mess up? I want to plug in an identicle soundcard.
The drivers will already be there for the primary soundcard.So will it automatically be fine?
The reason:
Understand yet?
