Good quality 1’’ tape types-brand?
  • Thread starter Thread starter tedsorvino
T
tedsorvino
Hi everyone. I’m about to enter the tape multitracking world in a more proper way, so I am very new to 1’’ tape.
I can’t find any 1’’ equivalent of my favourite Maxell (ud-xli) 1/4’’ I use so far with my 1/4’’ machine.
New RTM sm 911 - 900 is easy to find since I’m in Europe (ATR is in the states). Brand new. Not cheap. Rarely some used ones appear.
The equivalent slightly frequent used one is basf-emtec sm 900 (haven’t seen any 911). I think some other brands G9 type is equally good. Can’t remember if I’m correct or what brands.
I also know that Ampex 456 is to be avoided because of tape dryness, even if it’s the most frequent on used sites. But I don’t know if this applies to any 456 type, since it’s reputation makes me pass any 456 (quantegy etc).
So what other good types-brands (let’s say +6 or +9 db max) can be found used?
Thanks in advance
Any used tape should be approached with caution.
Maxell did not make tape beyond 1/4” as far as I know.
It’s not just tape “dryness” (flaky shed” to be concerned over but more so sticky shed.
Ampex/Quantegy 499 has fared better over the years but is not at all impervious to sticky shed. It’s inevitable. Quantegy-branded will be newer and therefore a better chance of being okay, but the best bet is new RTM. BASF/EMTEC 911/900 also seems to do better but is harder to find and commands a price. You could also look for Pyral 911/900.
What machine are you running?
Thanks for the useful info. At the moment I’m not running any machine, but I’m about to repair a Bernell mini 8. Quite some work but eventually it will ask for some tape. That’s why I asked mainly for ok used. Testing some not crucial parts on good used tape (like tape alignment-zenith etc) is handy.
Test tape also is an issue since I’m not a business…Extreme cost, but I guess it’s inevitable at some point. My 1/4’’ test tape proved itself very useful over the (few) years I’m back to analog.
Pics of the Mini-8 please. Very cool.
Test tape…very much not just for repair shops. If you own a tape machine it should be maintained. And a test tape is a fundamental maintenance tool. So it has to be included in the budget.
Be mindful of minute differences in tape width between Ampex/Quantegy tape and everything else. It can be problematic if the existing wear path was created by the former and you switch to anything in the latter category. I can explain more. Do the heads on the Mini-8 have edge slots?
At the moment it’s only booked. It will soon be with me. Yes the heads have edge slots.
I think I will stick with 911 (rtm, pyral, e Ted, basf) since I’m in Europe (ampex 499 1’’ is less common than the others here).
Eventually I will start a new thread in this great site since I’m sure I will ask some help and advice from the more experienced members. Some of them have the same machine.
The AGFA/BASF/EMTEC lineage is good.
Do keep us posted. The Mini-8 is a rare and very cool machine. I’ll have to refresh my memory as to whether or not I have any tech docs on it. I think not.
Thank you for all the info. I’ll do keep you posted.
Luckily enough Allen and heath site has a very detailed Brenell document section. Of course with old machines things may have been revised or modified or plainly different to the ones in paper.
I’m aware of the website, but don’t recall finding any technical documentation…just the sales brochure and owner’s manual. Can you post a link to what you are referring if there’s more (service instructions, schematics, layouts, parts lists, etc.)?
This is fantastic.
Thank you!
Yeah keep us posted. Congratulations. Very cool machine.
I used to look after a Mini 8. The biggest problem with it was short circuit tantalum capacitors on the audio cards. If you need the heads relapped then Terry Summers is the man to go to in the UK.
Forget about trying to use any Ampex/Quantegy tape - it has almost all gone sticky by now. I found a sealed reel of Quantegy tape from 2002 recently. When I opened the pack it was obviously sticky.
New RTM tape seems to work well - I've used both half inch and quarter inch 911 recently with good results. If you are in mainland Europe then Thomann in Germany are a good source. In the UK I'd suggest ordering from Studiocare in Liverpool who have a decent range of different types of RTM tape.
Thanks for the advice. I have to admit that I’m much more experienced in audio electronics than tape mechanical parts maintenance.
I’m in Greece actually. I know about Summertone. I’ve got mr Summers site. Yes sure rtm 911 seems like a safe bet. They have good prices on their online store in France too.
The good thing with mini 8 is that if it’s well repaired and work fine, tape bias, eq etc is really easy.
Yes, SM911 is probably closest to what the machine was designed for. SM900 is a 499 equivalent, but neither formulation existed when the Brenell was designed, so SM911 would be the best bet.
Thanks a lot. Thought about it at a later stage. I checked also the thicknesses data just to have an idea of equivalent for older feel “noisy” ones (lower mol)
I’m working through some of this right now…getting my Tascam 58 dialed in mechanically and electronically. I have a mix of Ampex-branded 456, Quantegy-branded 456, and a reel of Ampex-branded 499. The tape has all been sitting for a long time, like 8 or 9 years. Always in a climate controlled setting, but it’s all used tape. The Ampex 456 I’m not even going to try. It’s from 1998. I haven’t tried the 499 yet. Date code on that is from 1996. It might well still be okay. I have a bunch of 1” and 2” 499 for my Ampex MM-1000 and it’s a mixed bag…maybe about 50/50 at this point. It’ll all be sticky eventually. The Quantegy 456, one reel has date code from 2003. It’s starting to go sticky. Not really bad, but leaves a bit of yuck on the guides and lifters if you library wind the whole reel. And there’s a little bit of squeal every now and then. So it’s not totally gone but it’s way past being usable. Then I have three Quantegy 456 reels dated 2006. It’s still usable. There’s the smallest bit of yuck on the lifters mainly if you shuttle the while reel…library wind…like a flake of black across the wear pattern, and that only happens on the first pass, after that it’s fine. No squeal, tape runs nice. But, it’ll be sticky eventually. So your best-bet as advised is to just get new tape. I’m planning on selling the 58 soon and so it doesn’t make sense to buy new tape when, in my assessment, the 2006 Quantegy 456 is still okay. The crap shoot is, depending on storage conditions, I’m sure there is plenty of sticky 456 out there right up to tape dates like mine, which was at the very end of the company’s production. So just because I have some that’s usable doesn’t mean it’s all usable.
Oh and I agree +6 tape is the best bet for the Mini-8. +3 tape is another option if you want super saturation capability well ahead of clipping the record amps.
It is possible that it was originally designed to be used with BBC standard tapes. There's a good article on tapes used at the BBC, particularly type 200 at
I've had quite a few 3M 256 tapes through here over the last few years and they have all been good.
256 or 250? I’m not familiar with 256. If you’re talking about 250 that’s amazing…that was some of the first stuff to go.
I was quite lucky and found 3 good used pancakes of 1’’ Basf studio grade (2 x LR 56 P and 1x SPR 50 LH) came my way. So I have another taste for future use (except the brand new sm 911)
Since they are pancakes and empty 1’’ (3 screws type) are not very common cheaply, I wonder if I can use my 1/4’’ aluminium reels with the appropriate 1’’ rivet-screw combo set.
Has anyone any idea what the exact dimensions of the 1’’ reels rivets and screws are?
The thing with what you are doing hinges on the magic word 'used'. I baulked at spending £70 a reel on brand new 1/4", but every reel of used tape I bought had issues. Some were just horrible, shedding oxide everywhere and the few good spools reveal the occasional dropout or crease in the entire length. Great for testing, but so annoying when you recorded something and discovered on replay it was wrecked. Like secondhand tyres, or lightly used engine oil. what is the point of a nearly perfect spool of tape that requires wearing it a bit more to test it?
