Firewire adapters/cards?????????please help..........
  • Thread starter Thread starter jerzeysk8board
J
jerzeysk8board
I need a firewire adapter/card for my laptop, i have a firepod, wat is a great sounding one? wats the difference between 64 bit,32 bit,24 bit? please answer.......
another question..........................
would i need a firewire soundcard if i have a laptop and a firepod? What would it do? Which firewire sound card would u recommend? please help
does your laptop have a firewire port already? If not you'll need to get a card. Go to futureshop or bestbuy or whatever...they should have one and they're all pretty much the same. Presonus will have a compatablity sheet or something on their site. Make sure the one you get is on that list.
Jacob
just as clarification, the firewire port that your firepod hooks up to in your computer is not a soundcard, rather, the firewire port is just a place to plug things in to your computer, like a USB port. The sound card, or interface, is actually your firepod.
Um, not at all.
Check with presonus and see what they reccomend. I know for a fact the Yamaha hardware and Digi hardware has very specific requirements. I also know for a fact that Adaptec Firewire is on everyones "OK to use" list so go with that if you can find it
so that means i should just get an firewire adapter, if i get a firewire sound card it wont do anything with the firepod?
a firewire adapter is just something that gives your computer firewire ports.
A firewire soundcard, such as a firepod, is simply an audio interface that plugs into the firewire port in a computer. If you choose an audio interface that plugs into a firewire port, you will need firewire ports on your computer.
ummm, your Firepod is a firewire sound card!
