fender twin reverb amp
  • Thread starter Thread starter wrath
Have you made sure that the signal path hasn't been interupted. Check to be sure that the wires going from the preamp section to the reverb box (usually at the bottom of the speaker enclosure). Also, since the Twin Reverb is an all-tube amp, you may have a bad tube that controls the reverb mix. Any good guitar shop can check the tubes. I do suggest you contact the folks at Fender or an authorized service center. I know Fender has a web site but I can't recall the web address. A fast trip to www.excite.com
will take care of that.
Peace, Jim
I have that problem,
it happens like every 4 years for me, i just replace the pedal and it's fixed, but it's not that gooder reverb anyway.
HAWLK
PS TWIN REVERB is the best amp ever made.
I know Im about a month late on this, but you might try taking about the reverb box. I've done this on my Yamaha and my polytone amps, and found that the actual reverb spring was either unhooked, or broken. It was pretty easy, and Im not very technical.
jimistone
Replies
13
Views
2K
Sky Blue Lou
Sky Blue Lou
T
Replies
7
Views
514
ecc83
E
M
Replies
0
Views
533
Martin J
M
FrankD77
Replies
8
Views
2K
FrankD77
FrankD77
