fender guitar replacement necks
  • Thread starter Thread starter dragonworks
dragonworks
dragonworks
Banned
From Warmoths website:
Fender pioneered the detachable neck concept 50 some years ago. To this day, they continue to use the same basic dimensions on most of their offerings. Many other manufacturers have adopted these same dimensions into some of their own products (Kramer, ESP, Ibanez, Schecter, etc.).
Unfortunately, this is not universal and therefore problems of fit do arise. Warmoth has held to the Fender dimensions in all our offerings (exceptions noted).
To check compatibility of non Fender instruments, the simplest method is direct comparison. In lieu of this, the critical dimensions for guitars are: Neck pocket depth 5/8”, length 3”, and width 2-3/16”. Scale length (measure from nut to 12th fret x 2) is 25-1/2”, distance from nut to 12th fret, 12 3/4”, to the heel (not extended fingerboard) is 18-7/16”. Distance from heel to midpoint of bridge saddle adjustment is 7-1/8”.
The heel shape of Strat® necks is rounded at the end, Teles® are squared. Strat® necks will fit Tele® bodies but show a gap at the corners. Tele® necks may not intonate on a Strat® body without neck pocket modification
Attachments are pictorial specs for fender necks.
Are you looking for a fender neck? I have heard warmoth necks are really good. Having said that, I think that if you can find a matched neck and body you are better off. With a neck, that is not matched to the body, you will not only have to set the truss rod tension, but will also have to set the "pitch" of the neck with shims (not easy, but with patiance and persistance, can be done)
IMO, one is better off buying a guitar that plays pretty good, but may have a poor finish and electrics (pots, wiring, pickups)in poor shape....if you want to tackle a project guitar.
Strats are pretty easy to upgrade with hardware, paint, and electrical. Starting with a neck and body that are unmatched presents a harder challange.
You can but a used strat, in poor shape, for close to the same price of a brand new neck and body (or less)
