Robertt8
According to the Studio Projects website, the frequency response curves seem to be exactly the same for the C1 and the B1. Can that be right? Wouldn't that make them sound about the same?
Justin Hyatt said:The charts are often requested which is why we've put them up, and I like to have a pelthera of information on our products on the site. I'm all for having the most info on our site and not the literature I'd rather see people use the web not paper. But like chess said, charts do not reflect sound, put your trust in your ears if you like what you hear go for it if not try something else.
chessparov said:A big factor is that our hearing doesn't have a flat frequency response.
Ever notice how a crying baby's wail will cut through a noisy restaurant?
Chris
Glawfindle said:I agree with most of what you're saying Justin but.........'charts do not reflect sound.' Sound isn't easy to describe sometimes, is it? I thought that charts must reflect sound in SOME way. I agree that sound is the most important thing, definitely, and everyone should ideally demo a selection of mics b4 choosing, but to say that 'charts do not reflect' sound? What does it mean then when the SP website has the freq. resp. graph of the B1 and there is about a 5dB peak at around 10-11kHz? Does this reflect the sound or character of the mic at all? Does the B1 sound 'neutral' or 'flat' or is there a noticeable high freq. boost around 10-11kHz?
Are you saying that end users should not bother comparing specifications AT ALL, but just listen to them?
And I understand that the capsule often has a large bearing on the frequency responce of a mic. If this is true, and if the B1 and C1 have an almost identical freq. resp. graph - does this mean that they use the same capsule?
I guess you are correct in saying that charts do not reflect sound - especially if the charts are the same but the two mics sound different. What effects the difference in sound between the B1 and C1 then? Is it something to do with the the electronics or components? What has the main bearing on sound? Shouldn't the frequency response indicate a greater difference between the B1 and C1 - because they sound quite different? I thought that the B1 would have a flatter freq. resp. graph??
Please explain, cheers
Robertt8 said:I'm sure you did cover that somewhere in the 630 replies. I'll have to take a few weeks off to siphon through the worthless replies and the useful ones. I got to about page 4 when I ran out of paper.![]()
, but on the other hand.... it's a great thread and you'll learn a lot from it, I know I did, and I'm still learning. You might as well take time time to read it now... I'm pretty sure all the regulars here have read it more than just once. I still refer to it.Robertt8 said:According to the Studio Projects website, the frequency response curves seem to be exactly the same for the C1 and the B1. Can that be right? Wouldn't that make them sound about the same?
Brent Casey said:
B1 C1
+1dB @ 3kHz +1dB @ 4kHz
+2dB @ 5kHz +2dB @ 7kHz
+4dB @ 8kHz +4dB @ 10kHz
+5dB @ 10.5kHz +5dB @ 12kHz
+2dB @ 15kHz +3dB @ 15kHz
