B
Bigus Dickus
I know there are DX plugins and VST plugins. All of these plugins should work with any audio program supporting DX and/or VST plugins (DX with DX support, VST with VST support), right?
Question 1: Is the final quality dependant on the quality of the plugin, or the quality of the audio software doing the effect? It seems (from reading here) that some effects, reverb for example, can be found in a wide variety of plugins/softwares. It also seems that not all are created equally sonically. I'm wondering if the difference is in the algorithm of the plugin, or the algorithms the software uses to implement it (if there is even such a distinction, which I wouldn't think there is, but I want to make sure).
Question 2: Are there proprietary plugins? In other words, are there plugin packages for SoundForge that only work with it, and are better/worse than the proprietary plugins for Sonar?
Question 3: Is there anything else about effects plugins I should know about? I'm trying to decide which software to purchase. It would seem that, aside from the number of tracks the software can handle, the quality of its effects would be the major distinguishing feature. However, if all the plugins are standardized, then shouldn't n-Track render the same sonic final result as, say, ProTools?
). Slackmaster is the only guy I know around here that has actually written a VST plugin, the Suck Knob, and he might have a little more insight into what goes into mixing things via DSP. I will ask him to reply with whatever insight he might provide. But I doubt he is going to be able to shed much more light into this subject.
