dainbramage
I'm just going to cut straight to the chase.
The amp is a Heritage Victory. They are no longer made and the documentation is scarce to say the least. A manual exists but it contains no technical information at all.
The more I turn up the reverb on my amp, the more it hisses (well, it's not a consistent hiss, a little scratchy, and sometimes it starts to "whistle" as described by someone else in another thread, but that is only occasionally.)
The noise does not become louder the more I turn up the volume of the amp itself.
Now, the amp has 4 preamp valves:
1. 12ax7
2. 12at7
3. 12ax7
4. 12ax7
After a lot of searching around on the web I figure the 12at7 tube is the one related to reverb. (Or is it?)
My questions are these:
1. Would it be safe to replace the 12at7 with a 12au7 in order to find out whether or not a tube swap would fix the problem? I have a couple of those lying around. According to some people, a 12ax7 tube would not be safe on a Fender Deluxe, which is kind of like my amp in that it also uses 12at7 tubes.
2. If a tube swap does not work, what else could it be? Do some reverbs just naturally hiss?
1. 12ax7
2. 12at7
3. 12ax7
4. 12ax7
