Results 1 to 9 of 9
Thread: What mic do I need for my tascam dp-01
  1. #1
    Join Date
    Feb 2020
    Posts
    9
    Thanks
    0
    Rep Power
    0
    Sign in to disable this ad
    My shure sm58 doesnít seem to be giving me a signal.
  2. #2
    Join Date
    Dec 2002
    Location
    Massachusetts
    Age
    72
    Posts
    4,597
    Thanks
    13
    Rep Power
    10181460
    What are you using for a cable? The DP-01 has unbalanced 1/4" (6.3mm) inputs. (DP-01FX does have XLR's) The SM58 has an XLR connection. Wrong cable (not wired to transition from balanced XLR to unbalanced 1/4") may prevent signal from getting into the DP-01.
    Does the DP-01 see signal from an electric guitar or other source?
    Mark.......
  3. #3
    Join Date
    Feb 2020
    Posts
    9
    Thanks
    0
    Rep Power
    0
    Yes the other instruments are getting signal fine. Itís just the sm58 thatís not connecting (
  4. #4
    Join Date
    Oct 2005
    Location
    Ranelagh Tasmania
    Age
    69
    Posts
    8,505
    Thanks
    240
    Rep Power
    21474859
    What cable are you using (See Arcaxis's post above)?
    Do you another cable that you can try?
    Can you try the mike somewhere else?.
  5. #5
    Join Date
    Feb 2020
    Posts
    9
    Thanks
    0
    Rep Power
    0
    So what do you suggest I do to get past this very unfortunate barrier (
  6. #6
    Join Date
    Feb 2020
    Posts
    9
    Thanks
    0
    Rep Power
    0
    My machine is a do-01fx/cd. And it has the XLR inputs
  7. #7
    Join Date
    Feb 2020
    Posts
    9
    Thanks
    0
    Rep Power
    0
    I meant DP-01FX/CD
  8. #8
    Join Date
    May 2013
    Location
    South Florida
    Posts
    1,290
    Thanks
    341
    Rep Power
    3037326
    Assuming your SM58 worked before and then suddenly stopped........unless you dropped it pretty hard.....(VERY HARD)......it's likely the cable. If the SM58 is new and it never worked.......that's different.
    Just A Song Writer..........
  9. #9
    Join Date
    Dec 2002
    Location
    Massachusetts
    Age
    72
    Posts
    4,597
    Thanks
    13
    Rep Power
    10181460
    Quote Originally Posted by Douglaswayne View Post
    And using an XLR to XLR cable(?)
    Mark.......
Thread Information
Users Browsing this Thread
Similar Threads
  1. Tascam 134b + Tascam PE-40 + What Tascam/Teac Mixer??
    By Cratinus in forum Analog Recording & Mixing - Tape & Gear
    Last Post: 10-19-2012, 18:15
  2. Replies: 4
    Last Post: 05-05-2010, 16:46
  3. Replies: 0
    Last Post: 04-26-2010, 15:20
  4. Replies: 1
    Last Post: 03-16-2009, 08:45
  5. Replies: 0
    Last Post: 01-04-2005, 08:45
Posting Permissions
  • You may not post replies
  • You may not edit your posts
