Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: What mic is this?
  1. #1
    Join Date
    May 2019
    Posts
    5
    Thanks
    0
    Rep Power
    0
    What mic is this?
    Sign in to disable this ad
    Can anyone identify it from the picture? I've had it for years and it stopped working.
    ATTACH=CONFIG]104539[/ATTACH]
    Attached Thumbnails Attached Thumbnails 20190513_130045-jpg
  2. #2
    Join Date
    Dec 2002
    Location
    Massachusetts
    Age
    70
    Posts
    4,470
    Thanks
    9
    Rep Power
    10181459
    I would believe this one >>>> Audio-Technica ATM31 | RecordingHacks.com
    I have one that I bought back in 1990. Paid $139 for it back then.
    Are you operating it off the AA battery or phantom power?
    Mark.......
  3. #3
    Join Date
    May 2019
    Posts
    5
    Thanks
    0
    Rep Power
    0
    Hi Mark, my amp doesn't have phantom power, so there must be battery power, but I can't see how the battery is accessed. Maybe the battery leaked and glued the thing shut.
    I seem to have a memory of changing the battery years ago. I unscrewed every screw and the windscreen end. I know there's a battery in there because I measure about 200mV DC (as from a dead battery) going into the switch circuit board.
    Thank you very much,
    John
    Ahh... Just read the link you provided. Yes, it must be glued shut from a leaky battery. Hope I can salvage this thing. Thanks again.
  4. #4
    Join Date
    Dec 2002
    Location
    Massachusetts
    Age
    70
    Posts
    4,470
    Thanks
    9
    Rep Power
    10181459
    It should unscrew as shown below...
    Attached Thumbnails Attached Thumbnails atm31-jpg
    Mark.......
  5. #5
    Join Date
    May 2019
    Posts
    5
    Thanks
    0
    Rep Power
    0
    Yep, got it. What a mess inside! The top half of the battery disintegrated and the bottom half is stuck in there. I have some excavation to do! Thanks.
  6. #6
    Join Date
    Dec 2013
    Location
    essex
    Posts
    2,531
    Thanks
    13
    Rep Power
    3901875
    Good luck!
  7. #7
    Join Date
    May 2019
    Posts
    5
    Thanks
    0
    Rep Power
    0
    Red face Problem Solved
    Quote Originally Posted by rob aylestone View Post
    Good luck!
    It was tedious... but it's done. SUCCESS!
    I'll be sure to check the battery a little more often.
    Thanks!
  8. #8
    Join Date
    Feb 2009
    Location
    northampton uk home of Dr Who and Blackstar Amps!
    Posts
    9,738
    Thanks
    1
    Rep Power
    9256934
    Quote Originally Posted by Jazzjohn View Post
    Thanks!
    I seem to recall that you can wash out battery electrolyte with a solution of Sodium carbonate? Once bone dry a light spray of silicone oil will keep it protected, the stuff you spray on clothes irons.
    Join Date
    May 2019
    Posts
    5
    Thanks
    0
    Rep Power
    0
    Quote Originally Posted by ecc83 View Post
    Good tip. Thanks.
    John
  10. #10
    Join Date
    Dec 2002
    Location
    Massachusetts
    Age
    70
    Posts
    4,470
    Thanks
    9
    Rep Power
    10181459
    I'm thinking Dave may have meant Sodium Bicarbonate (baking soda) which could be used on an 'acid' type battery such as in a car. If the AA battery is an 'alkaline' type it takes a bit different approach and actually uses a mild acid to neutralize it. Just go easy to avoid liquid seeping into the electronics of the mic.
    How to Clean Alkaline Battery Corrosion | LoveToKnow
    How to clean a battery compartment containing corroded alkaline batteries..
    Mark.......
  11. The Following User Says Thank You to arcaxis For This Useful Post:
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
