I've got all the mics mentioned above, and they're all good for mic'ing Marshall cabs (I've used them all on lots of Marshalls, as well as other amps).
If you want tons of presence, the SM-57 will give it to you. You won't get a ton of bottom end, but you will get an "in your face" sound if you close-mic the cab.
If you want a smoother midrange and top end with a somewhat similar bottom end,
the e609Silver is a good choice. This is the mic I prefer when recording Teles through a clean amp... it's very easy to get an "accurate" sound, and it's the easiest mic of the three to position.
If you want a smooth, almost "3D" sound with plenty of options for the bottom end, I'd go with the 421. Personally, I think the 421 is the most flexible mic of the three, regarding recording guitar amps... clean, distorted, doesn't matter... it's never given me an overly bright or brittle track.
All three mics are usable for other duties too, especially with drums. If you've got the resources, buy one of each!
