Harvey Gerst said:Oxidation. Silver oxide is NOT a good conductor.
darrin_h2000 said:Mercury is the best conductor known to man but it melts at like -1000 degrees Kelvin. and its poisonous to boot. I wonder how it would perform in a signal chain without these properties.
Wil,Wil Davis said:
Harvey! I'm sort of surprised to hear you say that... I've always thought the exact opposite to be true...
The reason that gold is used for plating contacts in electronics is that gold doesn't oxidize easily, BUT gold is EXPENSIVE, so silver is used instead, and one of the advantages of using silver is that silver-oxide is conductive...
- Wil (somewhat confused...)
PS - I think silver is more conductive than gold, isn't it?
PPS - Contact Performance in Relays - link to info re. contacts and relays - long but interesting...
Harvey Gerst said:Wil,
I stand (or sit) corrected. Unless there is a problem with using a thin enough layer, I don't know the answer. My Fairchild mics are aluminum coated, and my Akai mics are nickle, so possibly silver would work, but I don't know why it isn't used.
This is really a better question for Stephen Paul or Karl Winkler, David Josephson, or David Satz to answer. I'll try to get an answer from one of them and report back.
Freudian Slip said:...To the best of my knowledge gold is a better conductor than silver. I don't think silver is very far behind though.
Wil Davis said:
