Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: shure 585SA unisphere opening
  1. #1
    Join Date
    Oct 2019
    Posts
    4
    Thanks
    5
    Rep Power
    0
    Sign in to disable this ad
    Hello i have this mic with me a old shure 585SA unisphere A
    unisphere-dynamic-mic-585sa-microphone-shure-bros-inc-35543662-jpg
    so im trying to open it and change the internal wires to a more superior quality wires to make little improovement
    i opened it and removed the screw from outside of the mic looked inside and the switch on off still seems to be attached to the inside of the microphone by some glue rubbered-foam, im thinking to use a plier to push the switch out but im kind of worry about doint that, also is there more thing inside the mic like small tranformers or something? im afraid after removing the switch i cannot remove the transformer, i know in the bottom of the mic there a soldering but its easily removable. thanks for any help.
  2. #2
    Join Date
    Mar 2010
    Location
    Boulder, CO
    Posts
    7,863
    Thanks
    21
    Rep Power
    14818761
    Using "superior quality wires" isn't going to improve the mic.
  3. The Following User Says Thank You to bouldersoundguy For This Useful Post:
  4. #3
    Join Date
    Oct 2005
    Location
    Ranelagh Tasmania
    Age
    68
    Posts
    7,896
    Thanks
    216
    Rep Power
    21474858
  5. #4
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    34
    Posts
    19,488
    Thanks
    1,212
    Rep Power
    1000000
    Quote Originally Posted by Aleksei77 View Post
    Hi,
    I think you'd need to remove both screws to remove the switch assembly.
    If there's any glue holding it you should then be able to break that seal by pushing the switch in, gently, from the outside.
    What they said, though ^^.
    Unless the wiring is damaged somehow, replacing it isn't going to make any difference to the microphone.
    ---------- Steenaudio Website ----------
  6. #5
    Join Date
    Dec 2013
    Location
    essex
    Posts
    2,925
    Thanks
    14
    Rep Power
    4008612
    To be honest, that mic was never a patch on the 565 so the slightly dull and tiny sound is quite normal. Normally mics are dull OR tinny but that mic managed both!
  7. The Following User Says Thank You to rob aylestone For This Useful Post:
  8. #6
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    34
    Posts
    19,488
    Thanks
    1,212
    Rep Power
    1000000
    Quote Originally Posted by rob aylestone View Post
    LOL. That should have been on their promotional material at the time ^^.
  9. The Following User Says Thank You to Steenamaroo For This Useful Post:
  10. #7
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    34
    Posts
    19,488
    Thanks
    1,212
    Rep Power
    1000000
    im afraid after removing the switch i cannot remove the transformer.
    If there's a transformer in there it's probably set in glue and tricky to remove.
    Really, I'm not sure there'd be any reason to remove it unless it was broken.
    I guess if I had to I'd remove all plastics then heat up the outer metal barrel and hope that the mass of glue softens up enough to slide out?
    Never done it...Just thinking out loud.
  11. #8
    Join Date
    Dec 2013
    Location
    essex
    Posts
    2,925
    Thanks
    14
    Rep Power
    4008612
    It was some kind of epoxy I think. I had a 515 that was high impedance and I tried to prise out the transformer and wrecked it. The potting compound was hard and brittle. The important thing here is to reinforce the advice that NOTHING inside, bar that transformer has ANY impact on quality. Changing an inch or two of cable does absolutely nothing at all to this mic, or indeed, any mic!
  12. The Following 2 Users Say Thank You to rob aylestone For This Useful Post:
  13. #9
    Join Date
    Oct 2019
    Posts
    4
    Thanks
    5
    Rep Power
    0
    I did some tests with focusrite interface on youtube
    /watch?v=rVSCJK8BBcw
    /watch?v=cDl9TVkdq-A
    ---------- Update ----------
    thanks i will leave it that way
  14. #10
    Join Date
    Dec 2013
    Location
    essex
    Posts
    2,925
    Thanks
    14
    Rep Power
    4008612
    Not sure why you're worrying - sounds very close if not so close I cannot tell. Amazing for such an ancient mic!
  15. The Following User Says Thank You to rob aylestone For This Useful Post:
Thread Information
Users Browsing this Thread
Similar Threads
  1. Vintage Shure UNISPHERE A.
    By The Axis in forum Free Ads for Music/Recording Equipment
    Last Post: 12-09-2007, 09:44
  2. shure unisphere dynamicmodel 5855b???
    By StudioMxpx in forum Microphones
    Last Post: 09-17-2005, 19:12
  3. From 32 to 16 bit.... without opening.
    By UberGawkman in forum Digital Recording & Computers
    Last Post: 05-14-2001, 15:03
Posting Permissions
  • You may not post replies
  • You may not edit your posts
