Results 1 to 3 of 3
Thread: Shockmount for Sennheiser E935 mic
  1. #1
    Join Date
    May 2016
    Posts
    26
    Thanks
    17
    Rep Power
    0
    Question Shockmount for Sennheiser E935 mic
    Sign in to disable this ad
    Hi, I wasn't sure whether to post this question in this forum or in the Gear Questions forum so I'll do both to be on the safe side!
    I'm about to order the Sennheiser E935 mic and, although I'm aware that it has an internal shock mount, I want to use it in a studio environment and so need to find a secure way of attaching it to my mic arm. It seems that the best way to so this would be with a shockmount and I wonder if anyone could recommend a reasonably priced one.
    According to the specs, the diameter of the mic is 4.7 cm. I'm assuming this would be at its widest point but I'm not 100% certain.
    As always, any advice would be much appreciated. Many thanks.
  2. #2
    Join Date
    Aug 2017
    Location
    Texas USA
    Posts
    2,494
    Thanks
    213
    Rep Power
    2308481
    Generally I don't think most folks bother shock mounting a handheld dynamic mic, unless the stand is on a floor that is not solid and folks are tromping/stomping around while recording.
    The shape (and weight) of the e935 does mean it's not going to fit in some of the light-duty kind of suspension mounts used for SDCs. I did find this one from Shure, that is designed for their mics, that might work, but I'd probably try to record with just the standard clip and see if you can actually hear anything that a suspension mount would prevent. (Or, that can't be addressed with a HPF or low shelf EQ in the DAW.)
    Shure A55HM Half-Mount Isolation and Swivel Snap-In Shock A55HM
    "... I know in the mornin' that it's gonna be good
    when I stick out my elbows and they don't bump wood." - Bill Kirchen
  3. The Following User Says Thank You to keith.rogers For This Useful Post:
  4. #3
    Join Date
    May 2016
    Posts
    26
    Thanks
    17
    Rep Power
    0
    Quote Originally Posted by keith.rogers View Post
    Thanks very much for your very helpful response, Keith. I'll take your advice and try it with the just the clip. All previous mics I've used have always required a shockmount so I think I need to get out of that mindset for this particular mic! Thanks again!
Thread Information
Users Browsing this Thread
Similar Threads
  1. Sennheiser HD280pro v Sennheiser HD380pro ?
    By 18pcs in forum Gear Reviews & Questions
    Last Post: 04-12-2012, 21:22
  2. Sennheiser e935 Cardioid Dynamic Handheld Mic
    By jgp57 in forum Microphones
    Last Post: 03-21-2009, 16:58
  3. Behringer xm8500 vs sm58 vs sennheiser e935
    By Diverdown in forum Microphones
    Last Post: 06-21-2008, 11:15
  4. shockmount
    By jacobmin in forum Microphones
    Last Post: 09-18-2006, 09:06
  5. Sennheiser e9xx series? ( e935 e945 )
    By tomleblanc in forum Microphones
    Last Post: 06-06-2004, 10:14
Posting Permissions
  • You may not post replies
  • You may not edit your posts
