Results 1 to 10 of 10
Thread: Rode K2 Issues Clicking and Popping in Vocals
  1. #1
    Join Date
    Apr 2011
    Posts
    29
    Thanks
    0
    Rep Power
    0
    Sign in to disable this ad
    I seem to get alot of clicking, Words like CATCH, KITE, COLD, that KA sound. plus other words. those are just examples. I have it wired to a Voice master pro amp, Waves don't even reach -8db and im like 8 inches away from the mic. No EQ really accept after i already laid vocals. I do Hip Hop and rnb. I also have a pop filter too. Can someone recommend a setting. Its also in a regular 10X10 room. No room treatment but still that can't be the reason. is it just the mic? anyone have similar problems?
  2. #2
    Join Date
    Oct 1999
    Location
    Eagle Winged Palace of the Queen Chinee
    Posts
    1
    Thanks
    33
    Rep Power
    0
    Try putting the mic above you and pointing the capsule at your forehead. Another old trick is using rubber bands to fasten a pencil across the front of the mic vertically centered on the capsule to break up the direct soundwave.
    Also, you're okay peaking at -18 to -12 dB.
  3. #3
    Join Date
    Apr 2011
    Posts
    29
    Thanks
    0
    Rep Power
    0
    so your saying my mouth doesn't need to be directly even with the mic??? Sing below it? do people really do that? and then u said recording at a lower Input gain around -18db... So i turn the beat lower or turn the vocals up after recording?
  4. #4
    Join Date
    Oct 1999
    Location
    Posts
    1
    Thanks
    33
    Rep Power
    0
    YouTube - vocal_clip1_plosives
    YouTube - Vocal Mic Positions
    As these videos explain, you can achieve different outcomes with mic placement. The K2 is a very sensitive mic. There is no need to be right on top of it for vocal recording. You don't want to be singing too much off-axis as that causes other problems, but placing the mic either above or below your mouth a little bit will give a little different outcome. You already have experienced that singing directly into the capsule isn't giving you the desired outcome.
    If you record too hot of a signal you don't have any headroom left for processing with compression and eq. Ideally, with good technique, mic placement, and the singer matched to the right mic and preamp eq is minimal and only used to help the track sit properly in the rest of the mix. Compression is what gives that "in your face" sound by reducing the dynamic range of the take-- raising the volume of quieter parts and lowering the volume of louder parts. This creates a track with more even volume throughout, and by altering the amount of compression and slope and the attack and release you can change the "punchiness" and the dynamic range to suit what is needed for the specific track. But compression is really an entire other subject.
    If your unprocessed beats are peaking at -8dB they were tracked too hot. In the digital realm you don't need to use all of the available headroom during tracking. The US standard is 0dBfs (digital full scale) equals +24dBu (analog). Tracking at -18dBfs is plenty hot of a signal for later mixdown and mastering.
  5. #5
    Join Date
    Jan 2005
    Posts
    1,540
    Thanks
    0
    Rep Power
    1112427
    ...the K2 has a very undesireable proximity effect...this mic does not favor close micing...give yourself at least 6-8 inches from the mic, and aim the mic a bit more towards your chest...these tips can improve vocal tracking with the K2 in my experience with the mic...
    reggae souljah
    "I returned to music through machines. The difference is that the machines are clean, and the machines are not corrupted...but you can bring an impure musician to play in your studio and create your own doom."
    LEE 'SCRATCH' PERRY
  6. #6
    Join Date
    Apr 2011
    Posts
    29
    Thanks
    0
    Rep Power
    0
    THANKS for those VIDEOs they were very helpful!
  7. #7
    Join Date
    Dec 2009
    Location
    New Hampshire Lat/Lng: 42.8129750,-72.0248270
    Posts
    25,766
    Thanks
    58
    Rep Power
    21474871
    Just wanna make sure the tube is fine and dandy probably is but just saying.
    ♫♪♫ I have a fever and the cure is cowbell ♫♪♫ .......... *LIVE FREE OR DIE* .......... ♫ I'm all ears ♫
    ☼ Mucho Loco Henry Areebah! ☼
    Any mic you buy will be perfectly suited to your needs, until you use it long enough to learn that it's not.
  8. #8
    Join Date
    Apr 2011
    Posts
    29
    Thanks
    0
    Rep Power
    0
    The tube inside the Mic? It looked fine.
  9. #9
    Join Date
    Dec 2009
    Location
    Posts
    25,766
    Thanks
    58
    Rep Power
    21474871
    And it is in it's slots nice and firm?
  10. #10
    Join Date
    Apr 2011
    Posts
    29
    Thanks
    0
    Rep Power
    0
    I just recorded some practice vocals and angled it like the videos said to and ALSO recorded at a lower gain. Mastered the track, n LOVED the quality! Thank you for your help
Thread Information
Users Browsing this Thread
Similar Threads
  1. Clicking and popping
    By coreycharron in forum Microphones
    Last Post: 01-26-2009, 10:00
  2. Clicking and popping
    By Steve West in forum Alesis Forum
    Last Post: 04-16-2006, 05:49
  3. clicking and popping...?
    By rockcamaro97 in forum Digital Recording & Computers
    Last Post: 10-24-2005, 00:49
  4. clicking popping
    By jlp in forum Cool Edit Pro / Adobe Audition Forum
    Last Post: 06-19-2000, 07:28
  5. popping? clicking? clipping?
    By skweeks in forum Newbies
    Last Post: 02-16-2000, 09:16
Posting Permissions
  • You may not post replies
  • You may not edit your posts
