Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: please, i need help (again) with recording my band's demo HEELP!
  1. #1
    Join Date
    Sep 2002
    Location
    Rio de Janeiro, Brazil
    Age
    34
    Posts
    28
    Thanks
    0
    Rep Power
    0
    Question please, i need help (again) with recording my band's demo HEELP!
    Sign in to disable this ad
    Hey, again..
    im using Cakwalk Homestudio 2002 to record my band's demo and im having some problems...
    the guitar sound is "flattened" u know what i mean? and its getting saturated u know, i think its the way im recording it..
    where should i put the mic when recording the guitar?? (the guitar amp, to be more specific)
    and the same about the bass!
    ps.: im recording with the mic connected directly to my sound card (sound blaster live!)
    does anyone use cakewalk homestudio2002? i really need some help adjusting the volumes and frequences of my tracks, just to get a little better (not PROFESSIONAL) u know what i mean...
    thanks for the attention, and sorry for my english, im from Brazil
    Marcos.
    ps.: if u want to help me with the frequences/volumes adjusts of my songs, id appreciate it! it would be easier with a more 'direct' contact, like AIM, or ICQ..
    There are known things
    There are unknown things
    and between them are The Doors.
    - Jim
  2. #2
    Join Date
    May 2002
    Location
    Atlanta, Georgia
    Age
    36
    Posts
    1,839
    Thanks
    0
    Rep Power
    340723
    Just a guess
    I use adats so i haven't really messed around with computer based recording. My guess is that your stuff is sounding bad because you are running the mic into a soundblaster live soundcard which is krap when it comes to recording. Your gonna need to get a different soundcard for better results. (some of the guys who use computers can recommend some).
    As far as micing guitar goes get a sm-57 and put it against the grill and put it a little off center aiming torwards the cone. Aiming at the cone will give you alot of high-end and the further from the center you will get less. Just put on some headphones and listen as you move the mic around. Find the spot you like.
  3. #3
    Join Date
    Sep 2002
    Location
    Age
    34
    Posts
    28
    Thanks
    0
    Rep Power
    0
    yeah, but i dont have the money to buy a bertter sound card :/
    but im almost sure i can do something related to equalization and graphic stuff (frequences) to get the sound a lil better.... i just dont know about those things :/
    Marcos.
    thx for the advice!
    - Jim
  4. #4
    Join Date
    Jul 2000
    Posts
    1,213
    Thanks
    0
    Rep Power
    21
    what kind of mic is it?
    many people record bass straight in rather than micing the cab
  5. #5
    Join Date
    Sep 2002
    Location
    Age
    34
    Posts
    28
    Thanks
    0
    Rep Power
    0
    its a roland dr-20 .......
    great idea dude!!!!!!!!!!! ill rec the bass directly to the sound card, it was getting pretty noisy and distorted when miking the amp.. thx alot!
    Marcos.
    - Jim
  6. #6
    Join Date
    Feb 2002
    Posts
    1,040
    Thanks
    0
    Rep Power
    304501
    Cool
    make sure that all of your levels are not distorting, never eq anything while your recording and what type of mic are you using
    to record the guitar?
  7. #7
    Join Date
    Feb 2002
    Location
    Upstate NY
    Posts
    3,472
    Thanks
    1
    Rep Power
    4185786
    When you record the guitars with the mic you need to use a pre-amp and then run a line-in to your soundcard. That will give you a much better sound than running the mic directly into the soundcard. I use sm-58's to record the cabs with the mic about 6" out from the grill on the edge of the speaker pointing it towards the center. You may want to give a try at recording with two mics in different locations for a stereo effect or recording a separate track directly into the soundcard from the line-out of your amps and then later on mix that with your mic recording. Eventually you'll only be limited by you imagination. Good luck, have fun and welcome to the forum!
  8. #8
    Join Date
    Dec 2004
    Posts
    4
    Thanks
    0
    Rep Power
    0
    I advice you to use a newer and different soft.
    (Cooledit Pro,Cakewalk Guitar Pro, Magix Music Studio, etc, etc.
    And of course better: guitar-amplifier-sound card for a good sound.
  9. #9
    Join Date
    Apr 2003
    Location
    Los Angeles
    Posts
    1,219
    Thanks
    0
    Rep Power
    28894
    I don't think that most of the problem is cakewalk or soundblaster. I think the problem is going direct from the mic to to the soundcard is the problem If you are going to the mic-in then you are using the crappy preamps on the soundcard and if you are going to the line-in then your signal is too weak. If you get a preamp and go to the line-in then the soundblaster can produce reasonable sounding recordings.
  10. #10
    Join Date
    Oct 1999
    Location
    Michigan
    Age
    48
    Posts
    1,006
    Thanks
    0
    Rep Power
    0
    Quote Originally Posted by dan_r
    .....and the two year old thread is resurrected! Sorry, couldn't resist.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
