planetorange
Are there any modifications that can be done to this mic to improve its sound or performance?
planetorange said:Hey listen dumbass, i wish i was you with nothing better to do than try to tell me your piece of shit mic is better than my piece of shit mic. For all your dumbass knows im working on a project and i WANT or even NEED to know about MODIFICATIONS not hear about your cheap ass equipment. If i wanted your jokes id listen to your songwriting. Only helpful info please.
planetorange said:Im getting sick of all the dumbshits that are on these forums. I have tried a million times on forums to get actual technical help and no one ever knows how to do anything. The only thing people know is that THEIR chinese junk is better than other peoples chinese junk. Im done getting help here because most people (MOST) are not even musicians worth anything and basically they just want alot of equipment to talk about or show off. If everyones mics are so great, than how come everyones home recordings sound like ass? And please dont tell me about "musical taste".
giraffe said:sorry i can't help except to say that i don't like the mxl tube mic's very well
(with the noteable exception of the 77)
it's all just opinions
(but note, the mic has like 1 vocal detractor, not 5 or ten)
giraffe said:lots of people do help here, just not him.
kid klash said:One fairly easy upgrade is to replace all the electrolytic caps in the mic with polypropylene or polystyrene caps...
mshilarious said:Without knowing this circuit at all, some of the electros might not be in the audio path, and some might be too large a value to swap for polys (which are much larger for a given value). If there's a too-big electro in a critical spot, replace it with a better quality electro & bypass with a small-value poly.
kid klash said:One fairly easy upgrade is to replace all the electrolytic caps in the mic with polypropylene or polystyrene caps... they're much closer in tolerance, won't drift in value due to temperature changes or age, and will help open up the top end. While you've got the mic apart, check the solder joints too.
Carefully removing the plastic cover from the front of the diaphragm might help improve the overall balance, at the expense of making it more susceptable to wind blasts.
PhilGood said:BTW, Marik is the shiznit on this stuff. I get a great deal from him. kidvybes knows tube mics dang well and mshilarious is plain brilliant.
