wes480
Ok, I was doing some of my first recordings yesterday...after a lot of reading. WOW - this stuff is hard. I am using an aardvark Q10 ,and pretty nice mics...
my problem is this, I was recording totally dry tracks into cooledit pro. with the aardvark it has the software mixer so you can see what levels it is getting. for example on drums...I had to get it to where the average recording level for the snare was like, halfway into green (like -12db or so i think)..just so the drummer wouldn't clip it on a loud part. The tracks turned out too low in volume..and lifeless.
I know compression could solve this - my problem is...with only software compression...I still end up with a dull dry track? So, I could get an RNC, and run the snare mic into that first...before going into the Aardvark? And then i could get a good -1db or so signal...constant...is this the best way to do it - is there a way to do that with only software? or will i have to get an external box?
Another problem with that is, for the whole drumset...I would then want to get like at least 3 RNCs...getting expensive...seems like there should be a better way. or if my tracks are good enough, is recording at -12db ok...and I can bring the level up later cleanly in software compression? Without it starting to sound like tape.
I am a real newbie....everytime i have messed with compression...i end up with a bunch of noise.
thanks guys
-wes
thanks guys
-wes
