Results 1 to 5 of 5
Thread: looking for a lavalier that records like a ardioid or a shotgun
  1. #1
    Join Date
    Mar 2019
    Posts
    1
    Thanks
    0
    Rep Power
    0
    Sign in to disable this ad
    Hello,
    I am shooting documentaries. For years, I have been using a Sennheiser ME64, mounted on camera, sometimes switching to ME66 .
    For smaller cameras, I have used AKG C747.
    For a particular project, I now need to shoot with a "point and shoot" camera, very small in size. There is no way I can attach any kind of mike on this cam (no flash shoe and no sound input jack).
    So, I was thinking of attaching a mike to my body, just like a lavalier, pointing in front of me instead of pointing towards my head .
    Of course, a regular lapel microphone will not do, as lapel (regular "lavaliers") are designed to record voice at short distance. Whereas I want to record everything that is in front of me, at a 90 or 120 angle.
    Therefore, I am trying to find a mike , ideally the same size as a lavalier, or a bit larger - but with a cardoid (or even shotgun-like) pickup patern.
    In terms of connnections, I could use either XLR or a mini-jack. It could be phantom-powered, or not.
    I believe such a mike does indeed exist, but until now I had no luck in my browsing manufacturers sites. I'd be most grateful for any and all advice!
    Nicolas
  2. #2
    Join Date
    Dec 2013
    Location
    essex
    Posts
    2,534
    Thanks
    13
    Rep Power
    3901875
    Can you mount the 747 on your chest? That would do the trick for you, if you can fudge the mic? Most small lavs are omni - but there are a few cardioids. Sennheiser do them, and again, if you can rig a mount, then your problem is solved. Shure and Audio Tec do them too.
  3. #3
    Join Date
    Nov 2003
    Location
    Denver, CO
    Age
    43
    Posts
    3,636
    Thanks
    116
    Rep Power
    7968219
    I'd imagine that any omni would do the trick. If you clip it to your chest/collar, your body will block a lot of what's behind you, leaving mainly what's in front of you and off to the sides in the capture.
    The mic itself really won't care about distance. The inverse-square law is the one that cares about that
    They make lavaliers in both cardiod and omni patterns, and I'm sure there are some super and hyper cardioids out there as well if an omni is too wide but a cardioid is too narrow.
  4. #4
    Join Date
    Feb 2019
    Posts
    348
    Thanks
    28
    Rep Power
    0
    Quote Originally Posted by nico reio View Post
    Hello,
    Nicolas
    I doubt it exists like you want.
    Shotgun would be a big problem as you moved and it moved on your clothes.
    If you can use xlr with power then get a tripod and mount a real mike on top that you could use when it is stable and steady.
    Have to use a point and shoot? That makes no sense. You trying to hide the camera so they dont see it?
  5. #5
    Join Date
    Sep 2016
    Posts
    136
    Thanks
    17
    Rep Power
    2150
    Go here ..... micbooster.com
    The fella who has this company was a BBC sound man for 30 years. He will advise you/sort you out.
Thread Information
Users Browsing this Thread
Similar Threads
  1. lavalier vs shotgun (recording course at home)
    By Yoni Goldberg in forum Microphones
    Last Post: 11-18-2017, 06:30
  2. Lavalier Microphone with Smartphone?
    By volti23 in forum Microphones
    Last Post: 12-09-2012, 07:30
  3. AT Lavalier mics
    By ad0lescnts in forum Microphones
    Last Post: 03-12-2003, 16:24
  4. lavalier mics
    By jax in forum TASCAM User Forum
    Last Post: 03-12-2000, 16:12
Posting Permissions
  • You may not post replies
  • You may not edit your posts
