Results 1 to 7 of 7
Thread: How can I get this 1950's Shure 51S mic apart?
  1. #1
    Join Date
    Jan 2001
    Location
    Maryland, USA
    Posts
    246
    Thanks
    1
    Rep Power
    23341
    Sign in to disable this ad
    Hi Folks-
    I picked up this beauty at a yard sale, and would like to refurb the inside--the foam is rotten. The problem is getting it apart.
    img_9969-jpg
    There are three machine screws holing it together--two were easy, they are accessed from the rear. The third is hidden beneath the little Shure emblem at the top. It doesn't pry off easily--it seems to be glued in place.
    Does anyone have experience with this? Does it take heat, or a solvent to break the seal and loosen that badge?
    Thanks in advance for any help--
    Chris
    "Here is a sunrise...Ain't that enough?"
  2. #2
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    34
    Posts
    19,729
    Thanks
    1,235
    Rep Power
    1000000
    Hi,
    I don't have experience with this mic but I found a picture of the exposed screw. Maybe you've already seen one?
    screenshot-2019-05-23-00-01-48-jpg
    As you can see it's only glued on quite a fine ring around the edge.
    I've no idea if it would take heat or solvent without damage but it looks like it could be carefully worked and/or prised with a fine blade?
    ---------- Steenaudio Website ----------
  3. The Following User Says Thank You to Steenamaroo For This Useful Post:
  4. #3
    Join Date
    Jan 2001
    Location
    Maryland, USA
    Posts
    246
    Thanks
    1
    Rep Power
    23341
    You, Sir, are a Prince among Men! I appreciate you taking the time to find that--I had NOT seen it, and it's going to be very helpful. I think you're right, that the glue must be not too deep. Going to start with a little moisture and move up from there.
    I've tried to prise it loose with an exacto blade, but the badge is soft aluminum, and I can see I'd damage it before getting it off that way. The microscopic chip of glue I was able to get out of the gap looks a lot like hide glue that I see in guitars. So moisture and heat should do the trick, if I'm right.
    Thanks so much for the image. It'll help a lot!
    Chris
  5. #4
    Join Date
    Aug 2017
    Location
    Texas USA
    Posts
    2,408
    Thanks
    205
    Rep Power
    2308480
    Shure might have that piece as a spare - can't hurt to ask. I'd bet their standard repair procedure at the time was to just pop the old one out and stick a new one on.
    I'd work that Exacto around the edges and just drip some water or maybe dilute rubbing (wood might remove the paint) alcohol on it and let it sit for a good while. A little heat from a heat-shrink gun is all I'd apply, and carefully. Still could remove the logo before you're done. Good luck.
    "... I know in the mornin' that it's gonna be good
    when I stick out my elbows and they don't bump wood." - Bill Kirchen
  6. #5
    Join Date
    Jan 2001
    Location
    Maryland, USA
    Posts
    246
    Thanks
    1
    Rep Power
    23341
    Success! I soaked the spot overnight with water (a piece of paper towel on it, angles just right so it wouldn't run away) and gently attacked it again this morning. In the end I think I was just lucky--there was more glue on one side than the other, and I just happened to be working on that side when it moved. It's not hide glue after all--it looked more like contact cement, something like that. It has a slightly flexible quality to it, something hide glue wouldn't. They used it all around the rim where the parts meet, too.So I'm not even sure the moisture did a thing! Just luck (or perseverance, which sometimes coincides with luck).
    Thanks for the help and encouragement! Hopefully these pictures will help someone down the road, too.
    img_9977-jpg
  7. #6
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    34
    Posts
    19,729
    Thanks
    1,235
    Rep Power
    1000000
    Nice work!
    Thanks for coming back to let us know.
    As you say, maybe it'll help someone else out some day.
    Would love to see what you get up to, now that you've cracked it open!
  8. #7
    Join Date
    Jul 2000
    Location
    Ontario California
    Posts
    1,448
    Thanks
    0
    Rep Power
    177034
    Quote Originally Posted by keith.rogers View Post
    A little heat from a heat-shrink gun is all I'd apply,.
    Heat from a heat shrink gun "could have had" a disastrous result to that mic
    Chance Pataki
    The Musicians Workshop
    musicians.workshop@gte.net
    http://www.the-musicians-workshop.com
Thread Information
Users Browsing this Thread
Similar Threads
  1. 1950's style reverb
    By jpb123 in forum Mixing Techniques
    Last Post: 02-08-2014, 14:35
  2. 1950's Hollowbody neck joint
    By fendersk8911 in forum Guitars and Basses
    Last Post: 12-30-2010, 08:38
  3. getting 1940's to 1950's retro sound
    By megak in forum Recording Techniques
    Last Post: 12-17-2008, 15:14
  4. 1950's'
    By RIMBAUD in forum Drums and Percussion
    Last Post: 04-21-2006, 09:03
Posting Permissions
  • You may not post replies
  • You may not edit your posts
