AVALON VT737SP Preamp
greyman
Hi there.........thanks for ur kind attention.........
I've been recommended AVALON VT737SP by a friend of mine.
This, as u know is a very expensive Preamp------need ur valuable advice--------DO YOU THINK IT'S WORTH US $2000 ???
Thanks--------
greyman
Well that completely depends on your current setup.. if you have very little or no gear, then no... it makes no sense. Spend the $2000 on something worthwhile. If you're at the stage in "the game" that you're looking at high end pre's then that's a different story.
What type of setup do you currently have?
ls
I've a good setup.
I use Cubase SX,Wavelab 4.0,HaLion,Reason kinda software----with TLM-103,AKG 414 kinda mics-----I use software FX and usually try to minimise the use of external gear. YAMAHA MSP10 are my monitors. I'm planning to add a couple of nice Preamps----
Presonus DigiMax--8Channel Preamp & A/D convertor with a couple of One or two Channel Tube Preamps(Art or Grace) were on my mind. But a friend of mine suggested the Avalon VT737----
I'm confused-----
regards,
greyman
