flatfinger
Use every dam bit!
OK guys,
I've been using the search function on this and many other forums so please don't beat me up cause I know it is a well worn subject!
Which camp do you fall into and why?
I know cardiod helps avoid bleed but you can't get them as close because of proximity, How effective is a roll off in this situation? 80 or 100 to 150 hz??
Are omni going to be quicker to set up because of there lack of off axis coloring???
if you go with a xy pair real close up , is there a "hole " when you pan well L& R
Share how you would go for the best "big" acoustic steel string sound for a singer songwriter , basic vocal, guitar w? mild rythum elements and nothing else?
What abou Ldc/ Sdc combos?
Discuss!
Thanks for your opinions!
Discuss!
