JimmyS1969
MOODerator
I am curious about how and why it is recommended for those new to recording to use the 'Direct monitoring' ability of an audio interface. I personally do not understand how that even works. Stay with me...
So, if you are recording a track using direct monitoring from any interface, are you still not having to perform to the DAW's output? I assume that gets rid of any latency while recording, but at the expense of not being able to have effects in monitoring without DSP ability or just hearing the mix from DAW output?
Granted, my system is not a typical off the shelf PC, and my interfaces likely have better performance than the lower priced stuff, but is that really that big of a difference between a interface with higher latency drivers and the system it is running on? I have never had such an issue myself though when I decided to do this at home (after experience in other digital based studios), I went with a more powerful system than some would likely go with. So I have a gap in what I am able to suggest to those starting out.
I consistently record vocals on fully mixed 60+ audio and 5 or so VSTi's running projects with buffer set at 96 samples with 5.96 ms of latency and no dropouts. There are VST's like FabFilter Pro L that create enough latency due to it's over-sample processing that creates an unusable delay while recording. But I just haven't wrapped my head around why I would use the direct monitoring of recordings.
Is this just based upon system abilities and or the interface and it's driver abilities to record at low latency? I feel I may have missed a step by going big at first and wish to know how to help others that haven't.
