B
bluelonestar
via chipset + amd cpu + and delta soundcard = loud crackling.
Just to share my experience with others who have a similar amd athlon (1800+)setup and are considering purchasing a delta 66 soundcard. They say it's compatible but really it's not. You'll get crackling on about 8 out of 10 recordings you make. I say that b/c usually it crackles and I'll be fooling around with it and think I fixed it. Then I'll go to do a take and it's right back. So, I've tried everything to exhaustion. I flashed my bios, downloaded the latest m-audio drivers, 4 in 1 drivers, windows updates, changed bios settings, changed the latency, changed every setting possible, added more ram, nearly turned off my graphics, changed pci slots, confirmed there was no irq conflicts. Tried everything m-audio and others on this forum suggested. I called tech support and the guy told me it was b/c I don't have ultra dma on my hard drive. Well, I have a seagate 80 gb 7200rpm hard drive with ultra ata 100. Which my motherboard supports and I have the 80 pin conductor cable for it. I even went as far as to download a utility from seagate to confirm I was operating at ata 100 speeds. So they say theyre compatible but really theyre not. My only option now is to switch mobo to intel pentium. The funny thing was I knew this already, but people have posted on here that the amd incompatibility was a problem of the past. Well I'm here to say NO ITS NOT.
