ENIGMACODE
Hello Home Studio Builders
I'm building a rehearsal room - my main concerns are absorption and isolation of sound (it's a free standing room built within my garage) There are NO contacting surfaces between the two rooms. The inside rehearsal room is completely free standing except for the concrete on the floor below the wooden subfloor. As I've read many of the posts here, I'd like to confirm a few things and cut to the quick in regard to the proper installation of gasket material and drywall:
Bottom wall plates (of the wall structure), should be fastened directly to the subfloor perhaps with some construction glue (with no gasket in between) Correct?
BUT
Gasket Material (should) be installed along the top of the wall plate where the cieling joists are fastened - Correct?
Drywall questions:
When installing drywall, should the drywall cover the 1/8" or 1/4" gap at the top of the wall where the gasket is?
OR should you actually leave a 1/8" or 1/4" space and apply no tape or joint compound leaving the gap exposed?
AND
It's my understanding that caulking SHOULD be applied all along the floor where the floor and walls meet BEFORE you apply drywall
Correct?
Thanx for your help
Best Regards
Michael Fraticelli
rocknroll@ucwphilly.rr.com
BUT
Drywall questions:
AND
Correct?
Thanx for your help
Best Regards
Michael Fraticelli
