Sax2
Punk
Hey all, first post.
I want to record my drum set. Right now, I've got a Shure X2U and an SM57 that I've just been putting above and behind the throne to make rough recordings, but when I add in guitar and bass tracks the snare and kick get really buried and lost in the mix, so I'm thinking getting some more mics is a good idea.
I'm thinking I need a snare mic and kick mic at the minimum. I looked through some of the posts in the drum forum, and they usually suggest getting two overheads, but I think I could scrape by with just my SM57 for now, and get another one later if need be.
I also need an interface with more inputs/preamps, as the X2U only has one. I'm thinking at least four, keeping with the kick-snare-two overheads idea. Eight would also be fine, then I could use it to make less awful recordings with my band. It should be compatible with ProTools, as I hope to learn how to use that.
My budget is around $1000, could go a little over if it's worth it.
I guess I also need to buy a ton of cables, too, to connect everything.
