WhinyLittleRunt
Member
Ok, 38 experts...
I dug out my Tascam 38 tonight after more than 4 years in the hopes that I might finally be able to get it working, or at least do a better job of assessing the issues. In truth, the unit hasn't worked 100% since I got it back in 2009. I've done a considerable amount of "n00b" work on it, like replacing all the VU bulbs, changing the drive belt, and reflowing the solder on the main connector board. It got so frustrating having a machine that barely worked, that I just dumped it to the side and when I found a 388, I bought that and never looked back... but from time to time would take out the 38 and set it up, thinking I knew what I was doing...
Well tonight I did know what I was doing, because I was finally able to fix a lingering erase problem that was the reason I left it for dead in the first place. It turned out that I had arbitrarily just messed with the adjustment of the master oscillator years ago, and by doing so I created a signal and erase problem that I could never seem to fix. So the other day I finally ordered a replacement oscillator board (Teac sells the actual oscillator still but the pulled part on the bay was cheaper and if it turned out to be a fried transistor or something, they're not common or available parts). Knowing I was getting a replacement I pulled the original one out and removed the adjustment screw entirely. Fortunately I had marked what direction it was set, but not knowing how many rotations to get back to the precise spot... so I put the adjustment screw back in all the way and began backing it out, lining up the notch with my old pencil mark, and recording some audio into a known-working channel. Each time I did this, the audio was choppy, clicky, going in and out, sometimes barely audible. But I repeated this process of backing out the screw and testing until I finally had a very clean recorded signal and was also finally able to erase that track!
With that 'fixed' (hopefully), I started testing out the individual channels and making sure they work in sync and playback in repro mode. I do have channel issues though. 1 and 4 did not get any audio signal on the VU meters nor did it record. One other channel, I think it was 6 but I can't remember now, got audio signal on the VU but didn't record (this one is questionable as I was rushing to record on all tracks in a specified order and possibly forgot to arm the channel). Anyway, here's what I found with the two known-bad channels:
-Channel card 1 did not work but after a series of reseating it, it finally started working. I don't trust this.
-Channel card 4 works in a different channel slot. Tested a known good card in slot 4 and got nothing. So I assume it's a backplane problem (the one I spent all that time reflowing..)
-The channels that do record work well, although they all sound slightly different. In fact, now that I think of it, I believe channel 1 was working when I recorded some test patterns and it was really distorted compared to the others... I know this could also be an alignment problem with an outside track. But some sound muddy, for example, compared to a good one that sounds very good and clear.
If I want to troubleshoot this any further, I suppose I will need to invest in an MRL test tape. For an intermittent card, or non-working card, what are some of the more common issues? Relays? Would it serve any benefit to recap the channel cards? Power supply?
I'm really trying to decide if it's worth keeping the 38 for the future, and if I go that route, I will probably go full-on restoration with it (to the limits of my ability). I know these are prone to similar failures and have caught a bad rap for being fairly unreliable, but they're probably getting fewer and fewer and not any cheaper, so I am inclined to hang on to it; my studio can't really facilitate its use due to space, but I'm not going to be in this house forever...
Any tips on how to troubleshoot and compare a working card on a scope or meter?
