GCalo
Member
I wanted to repaint the cover of a Tascam piece I have that was scratched.
I contacted Tascam parts and asked what the paint was. Of course their answer was that the color has been discontinued! DAH what a surprise.
I then went to the local Kelly-Moore paint store, and they were great but informed that they could only provide a semi-gloss in water or oil base! Well the OEM paint did not look semi-gloss to me. So, what to do!
Salesman suggested I check the Rust-Oleum spray paints they had.
Well low and behold I found a can that is almost a dead -on match! It is very, very close, and it is flat.
It is called the Anodized Bronze P/N: 209565.
So I sanded the cover with a #400 paper, and sprayed it. It looks great and is nearly a dead match. I was stunned.
I probably should have used a Rust-Oleum primer, though, because some of the scratches I thought I had removed are now showing through.
I need some advice from painting experts, however, because there are some uneven color streaks. I sprayed multiple like coats. There are no runs but there are uneven color bands.
So, experts, how do I spray this or any metal panel so the application is uniform and makes the panel look like it came out of a spray gun!
