Hello.
You're gonna be fine. It's usually a belt that's the problem, and rarely the motor. To access the belt, you'll have to:
- remove the plexiglass cover by depressing it to one side & lifting out, or just tape it down so it doesn't flop around. Either way is fine.
- either stand the 388 up on it's back end, CAREFULLY, or find some pillows or adequate padding, so that you may turn the 388 upside down, & carefully rest it on it's mixer surface, upside down.
- remove all screws on the bottom, & remove the bottom cover plate.
The belt's down there, in plain sight. I don't remember the exact size of the belt, & that would take me a short while to verify, but suffice to say, you can measure the defective belt, and source a belt that's just slightly smaller than the old belt. The old belt will be stretched out, by definition. Belts are measured in TOTAL length. I have a new 388 belt in my technical items in the garage, so it will take a while to dig it up and measure it, myself.
A suitable belt may be sourced from any good electronics supply store, or for 400% markup from Tascam Parts. Avoid the belts on Ebay, because they're inflated about 1000%. A  suitable belt sourced from an electronics store should be about $3,... or $12 from Tascam & $25 on Ebay. Your choice. Heh.
When I get a chance, I'll pull my belts out & measure them for you.
In the meantime, that will give you a chance to turn the 388 over and inspect the belt yourself. Not such a hard job.
It's probably best to turn the 388 entirely upside down for this operation, because if you stand it on it's back end, the bottom panel may fall as you remove it, and it could hurt someone.
If I sound scatter brained, I need sleep very badly.
Anyway, good luck, and I'll check back after a while.
