M
Matthew Walsh
Dear Recording Guys,
You've helped me out of a few audio scrapes in the past, but this one is pretty major, and may involve me having to re-record a good chunk of the music I've already laid down on my 14-song album project.
What I did was, I sequenced all my songs in MIDI, the guitar parts, the drums, the bass, the "standard" keyboards. I then recorded them into Vision DSP on my Mac using stereo tracks. By this, I mean, I'd record the bass, let's say, from my PROteus MPS keyboard, using its regular right and left outputs. They run into my mixer. When I record, I turn the right pan knob on my mixer all the way right, turn the left on all the way left, and record the information into my computer via its stereo input onto one stereo audio track on Vision. I do the same for rhythm guitar, for the kick drum, the snare, etc. -- but I always assumed you recorded a stereo instrument, particularly anything coming out of a stereo keyboard, IN STEREO, with the pan knobs all the way out to capture the full stereo. Right? The idea is to treat all the MIDI instruments like "real" instruments and record and effect them just as if I had a real drum kit, a real bass, etc.
Well, to further compound this, THEN, if something needs processing, I process it in stereo. Of course. Then, I record vocals -- in mono, of course, but I process them in mono-to-stereo reverb/echo, etc. so they sit with the other instruments. Right?
Imagine my surprise when I mix down the song, only to discover that the stereo spread is waaaaaaaay too much when you compare it to virtually anything else that has been professionally recorded in the last, say, eighty years. It sounds horrible and ameteurish and, furthermore, the levels are untenable; I never go over digital zero and yet I get distorted sounding levels, particurly the highs.
So what am I doing wrong? Assume you're speaking to a small, slow child, of which, in the home-recording game, I certainly am. I split the drum machine into Kick Track, Snare Track, Hats Track, Rides Track, Crashes and Toms. Everything else, I record straight from the keyboards, through my Mackie 1202 and into my computer, using the Mackie to boost or cut levels. I don't process anything during recording. I don't boost or cut EQ during recording.
To expediate recording and mixing, I usually mix all my instruments first on the computer. This, I mix down to two tracks (which I normalize in Vision to attenuate anything that might go over digital zero), then, I open a new file, which contains my bounced instruments on a stereo track and my vocals. I mix the vocals to the the stereo instrument tracks. Then, I mix down again to two tracks, which now contain vocals and instruments (and is normalized again to prevent clipping).
For a while, I was utilizing a third file, which contained my stereo mixdown. I would run the mixdown through a comp/limiter plugin to even out the mix and to make up the gain reduction the two normalizations had cost me. This was a mistake. Though I did not go over digital zero, the levels were too hot and distorted. Well, without this third step, nothing's distorted, and the peak is digital zero (somewhere in the song, anyhow!), but the general levels are too low. So I know I'm doing about eighty things wrong. Thanks in advance; any help is gonna be deeply appreciated ...
