Re: Presonus StudioLive AI series and mixing
I've watched many videos and read much info on these boards. In doing so, I see that you can use FW link on the board to actually mix on the board as opposed to mixing in DAW. I was wondering, though, if you mix on the board like they show that you can, will it save EQ and such if you have the DAW running, or is the only way to actually mix so your PC saves it, by mixing in the DAW itself instead of on the board?
